Lacquer over oil?
Lacquer over oil?
Dick Hines
Lacquer over oil?
Dick Hines
>That is the question. I turned a cherry burl that 1/2 burl and 1/2 air. I usely finish my pieces with watco oil and buff. I am concerned that while buffing one of the wheels will catch in one of the voids and break the burl.
I have used spray lacquer over oil on small pieces but after all my work I don't want to screw up this piece.
Deft laquer over Watco?
Re: Lacquer over oil?
Mark Strang
>Dick, I use Deft all the time over Watco. In fact, I use Watco on almost everything to pop the grain and bring out the color. From there I use Deft or any other product that I might want to apply. Mostly though I use a Deft type product. Just let it dry and you won't have any problem
jim Miles - Charlotte NC
>I use Deft spray lacquer over Linseed oil ( probably main ingredient of watco) all the time, no problems.
Allen Neighbors
>Dick, when I use lacquer over oil, I always let the oil cure for about a week. Then I use my lacquer wash (adapted from Carole V's mixture) and let that dry for a short period of time, then sand 400/600 and then spray.
I use Gemini Hi-bild Pre-Catalyzed Lacquer, reduced with 3/4 oz reducer per pint of lacquer.
The most important thing here, is to make sure the oil is cured.
Ken Oakley-Sunny St. Cloud, Fla
>I, also, have sprayed Deft lacquer over oil baseed stains such as MinWax for yeaars with no problems.
Dick Hines
Dick Hines
>Thanks guys. I will post a picture when I finish the piece.
GaryG in MD
>Dick, You might want to read www.woodcentral.com/russ/finish11.shtml
from "Articles/Russ' Corner" before you do it. It has lots of good info. ...GG
Russ Fairfield
>Dick, if you are going to put lacquer over an oil finish, new or old, it helps to prep the s surface with brush coat of lacquer. Buff the oil finish with 0000 steel wool, brush on a liberal coat of lacquer, wipe it all off while it is still wet, and keep wiping with clean paper towels until it is dry. This will remove any residual oil, dirt, fingerprints, wax, and other things that can cause problems with a lacquer finish; and lay down a base lacquer primer coat. Buff it again with the steel wool, and the surface is ready for a lacquer finish any way you want to apply it, spray, brush, wipe, or dipped..
