Weighted Tool Handles....
Wally Dickerman in Arizona
>Some time ago,I added lead shot to the handles of some of my scrapers. If I'm installing a new handle I bore the hole for the tool a bit deeper than needed and add some lead shot. I bore an even deeper hole at the butt end and add shot using a temporary plug. When I feel that I have it right I glue the plug in. I feel that adding weight to give the right feel and balance helps to give a smoother more controlled cut with little or no vibration.
I recently received a bowl gouge and a detail gouge from Doug Thompson. I added lead shot in the same way when I installed the tools in their handles. I really like the feel and control that the added weight gives.
I have a couple of Glaser tools that are weighted of course. I prefer the feel of wood so don't use them very often. Also, the Glasers are a bit heavier than I like. Experimenting with the amount of shot gives me the custom fit and feel that I want.
I used to do a lot of skeet shooting and reloaded my shotshells using #9 shot. #9 is the smallest sized shot generally available. It's the same shot that Jerry Glaser used. Fortunately for me, I have some shot left over from my shooting days. Shot is available at some gun stores. It's a bit pricey at about $50 for a 25 lb. bag. It actually takes very little shot when weighting a handle, so 25 pounds is a lot of shot. Get your club to buy a bag. There really is no subsitute for small sized shot when weighting a tool handle.
Anybody else do this? I really recommend it.
Wally
Re: Weighted Tool Handles....
Ron in Drums PA
>Just recently
I made a bubinga handle for Thompson gouge. I used bubinga because it is so heavy, but it wasn't heavy enough. I had a friend who gave me about 2# of #9 lead shot. I used about half, really made a nice difference.
Just yesterday, I was going buy some shot just to keep on hand. The best price I found was the same as yours (before shipping).
Shot Tower
Al Kapocius
>O'course you can make your own shot with a shot tower. Take a torch, ladle, some lead and a 25' to 50' tower.....
Pick a day where there's no wind.
Al Kapocius
try wal mart
robert davis
Re: Shot Tower
Bill Hale / The Wood Spinner
>Al
Do you need someone on the ground to explain to the police that the guy on the tower is not realy crazy.
Bill
I do, Wally.
Allen Neighbors
>A friend quit shooting, and gave me a bag of #9. I use it, and add a little more or remove a little, til I get it right. It works.
I've even used BBs before I got the lead shot. I've got BBs in most of my Oland tools which have black pipe handles.
Re: Shot Tower... (or is he?)
Allen Neighbors
gary s clarke
>Wally, Bob Sweazy sells bowl gouges that have wooden handles with added weight. A lot of people in the Seattle and Fife clubs are very happy with his bowl gouge. He uses high quality steel for the gouge.
Re: Weighted Tool Handles - 'free' lead
Carol - now in NC Nebraska
>used wheel weights from the tire store. They have to pay to get rid of them.
Ron in Drums PA
>While wheel weights do add weight, they don't do a good job in reducing vibration.
>I've done some turning on a friend's lathe that was a solid block of concrete with a steel plate on top with a spindle and bearings installed. He estimated that it weighed 1000 pounds. Surprisingly, it didn't take much to cause the lathe to vibrate. My Nichols weighed 800 pounds and I had 400 pounds of sand added. It was rock steady under most conditions.
A loose material such as sand or even better, lead shot, does much to reduce vibration. When I had a General 260 I had four 25 lb. bags of lead shot packed into the motor compartent under the headstock. Really worked well.
Wally
Re: Does it rattle?
Mike Rubes, Apex, NC
>Hi Wally,
I like the idea of adding the weight to the handle, but I have a question. Do you add enough shot to completely fill out the void you hollowed out, or does the shot roll around in there? If it does roll around, does that slight changing of weight balance throw you off when turning?
We've got a gun store just down the road that sells shot, but I've never given it a try. I've got a Doug Thompson tool heading my way along with a Dave Peebles handle. Right now, I'm still on the Jet Mini, so am limited to the size handle I can make. I would think I need something more than 12 inches or so for a gouge handle.
Also, how do you bore yours out for the shot? A drill press or while on the lathe? Seems like a steady rest would be necessary if you are drilling out a handle?
Thanks for the information and ideas. I hope all is well in Arizona.
Mike
Taking a day off to spend all day turning tomorrow in Apex, NC!!!
Re: Does it rattle?
>Hi Mike....Leave just enough room to allow for a very small amount of movement. Shouldn't rattle.
If you have a long bed lathe available it's easy to drill out a handle. Just install a jacobs chuck and drill in the headstock. Remove the live center from the tailstock. Center the handle on the tailstock and crank the handle. Drill slowly and get a good grip on the handle. If you don't have a long bed lathe available, then use the drill press and some clamps.
Use a bit more shot than you think is enough. You'll be glad you did later.
Wally
Wally, General 260?
Ruth Niles
>Wally,
I've been trying to figure how to weigh down my General 260 but there is no place in the motor compartment and no bottom. I'm assuming they are constructing this model differently? I have a shelf under the ways but it's got a slanted back so I'm thinking only 2 or 3 bags of sand would fit. Any thoughts?
Ruth
Re: Wally, General 260?
>Ruth, I bought my General in the early 80's. They came with a Reeves drive then, so it was a bit different than the modern day 260. Four 25 lb. bags of lead shot don't take up much space. Of course at todays prices you'd be putting $200 worth of weight in your lathe. Of course if you were reloading shotshells as I was at that time it would only be a storage space for the shot. Hey, why don't you take up skeet shooting?
Wally
Ruth Niles
>I tried skeet shooting and the blast knocked me on my ..... um, bottom! I like target shooting, can I use shot for that?
From what you wrote before, it looks like the sand is my best bet.
Ruth
Bill Howatt
>My General 26020 has bolt holes in the pedestals which I have bolted to the floor. Works well.
Bill
>C'mon Ruth, you can say Butt on WC...Little lady, big gun.
100 lb. of sand will take up at least 5 or 6 times as much space as lead shot will. A 25 lb. bag of lead shot is about the same size as a small loaf of bread. I used to keep 150 lb. of lead shot in my General. It just about covered the bottom of the compartment. With the Reeves drive the motor was suspended well off the bottom. I don't know how much space there is in the newer VS 260's.
Got a gun club in your area? I'll bet that a sweet young thing like you could get a deal.
Wally
Re: Does it rattle?
Bob Edwards
>I solve the rattle problem by adding hot candle wax in withe the lead.
I too get my lead from a tire shop.
Bob Edwards
San Antonio
Rich Egan
>If you only need a few ounces of shot, I suppose you could buy a box of inexpensive shotshells, open the plastic and dump out the shot. There should be an ounce or so in each shell.
