finding spalted wood
Gary Land
>I am wondering how people find spalted woods. Is there an article to read or someting.
Gary Land
DIY
>Some people "make" their own by placing log ends in moist soil. I have not done it so perhaps someone here can elaborate.
Tom
Re: DIY-It Works Tom
Ken Oakley-Sunny St. Cloud, Fla
>small enough pieces I put in plastic buckets, put the lid on and let it sit. After a while it is covered with nice fuzzy mold and that seems to kick start the spalting process. It can take months for the spalting to really become spectacular. I am not sure of the health effects of cutting this wood but at 75 it hasn't killed me yet.
Re: finding spalted wood
Stuart Johnson
>Cut your blanks and place in a trash sack with a mixture of Miracle
Grow and beer. Wet the piece down and seal up the bag. I haven't used it but Jamie Donaldson says it works great.
Now with Hackberry I had good luck just placing it in a plastic bag for a couple weeks. It will be nasty looking when you remove it.
Keith Tompkins
>This is spalted silver maple with ambrosia beetle damage. This was a fresh-cut tree left on the ground, endgrain in the soil, then covered. didn't take long to spalt! You can also place pieces in a plastic bag, add beer or yeast or your favorite brew....voila! Good woods to spalt are maple, ash, elm, holly, beech, and a few others. Hope this helps.
jim Miles - Charlotte NC
>Spalting is just an early stage of the wood rotting process.
As noted you can make your own. You asked how to find it. Look for woods - especially those mentioned in last post that have been cut and left out on the weather for 6 months to a few years, Firewood piles are good prospects. Cut into it & see what you find. Often a piece that looks like it would'nt even make good firewood will have a wonderful inside.
Easy answer- it's everywhere
steve antonucci
>Any log that you see on the ground for a while is likely going to have some spalt developing. The key for a woodturner is getting to it before it becomes rot.
Once it looks like what you want it to, you need to get it off the ground. Don't bring it inside, because if it dries to fast, it will check. Sticking it on top of compost/shavings/leaves/grass/organics is a sure fire way to kick off the process.
Steven
Gary Evans Tallassee, TN
>I have good luck with just laying the wood on it's side, just off the ground. I feel like you lose too much to rot and beetles when it's on the ground. Especially if you aren't paying attention. 8^]
I lost a really pretty hickory crotch by letting it lay directly on the ground.
Gary
>Where do you live? I have a big spalt pile. Every once in a while I pull something out and cut into it. However, most of the time I forget and it rots. If you are close we may be able to find a few pieces you can turn.
