Moisture Meter
elliott
>Does any moisture meter detect more than just the top surface of the wood? Or is it just a waste of $ to buy one?
Moisture Meter
elliott
Re: Moisture Meter
>Elliot, as a Home Inspector, I have had four moisture meters, some of them I have used in my shop. The meters with the pins actually detect the electrical resistance between the needles. The assumption is that he dryer the wood is, the greater the resistance. These meters would be basically measuring the resistance very near the surface.
The other meters are called "pinless" and they send out RF waves through the wood and read the "wetness" based on the flow of the waves. The theory being that the waves will pass more freely through wet wood. One such meter I had would read about 3/4" deep. There are models available that will read deeper.
Both raise issues of calibration. What you have to do is to have a dry sample and a wet sample of known moisture content to establish a base line for the meter. To be even more accurate, you would also have to have samples of wood of the same species you are measuring. In the real world, we rely on the meters to be reasonably accurate and to self calibrate. I never use mine to say that this "Whatever" has a moisture content of 16.095%. I use them in a comparative sense. I say, this area over here meters as wetter than that area over there. Therefore, I conclude that the area that is stained is wetter than the area that is not stained, therefore, I conclude that there is an active source of water, something is leaking.
Also, the pinless ones don't work well on curved surfaces. They need to be consistently pressed against a flat surface. So it would be somewhat difficult to sue them on bowl blanks. OTOH the ones with pins might punch objectionable holes in your blank, but those holes are actually very small.
