A55 Smoothing Plane
Platter Try: #2 & #3
Chris DiCiaccio
>Well, The first one is Red Cedar (6 3/4 x 1) and the second Cherry (9 x 1). I still need a lot of practice. Also need to learn to sand better.
Re: Platter Try: #2 & #3
Chris DiCiaccio
Chris DiCiaccio
Chris DiCiaccio
Cyril Griesbach
>They look real nice, Chris.
Mark Paulley
>Chris,
The people here at this site taught me alot about sanding.
1. Get a real good light on your subject. This alone helped tremendosuly. I got a 100W magnetic light from WoodCraft and it really has helped show even the smallest of scratches. I attached it to my headstock so it can direct light right down on the piece.
2. Get good sand paper. I use paper from VincesWoodNWonders
3. Do not use the same paper over and over. Sand paper is realitively cheap so use fresh sand paper often.
4. Do not move on the the next grade of paper until you are satisfied with with what the current grade has done.
Hope this helps. Its basic but it works!
Mark
Steven Reznek
>Soft woods, like cedar, are a lot harder to sand than hard woods. If you do very much sanding the surface will become corregated with the grain pattern. The solution is to get as smooth a surface as you can with the gouge. Use a very sharp gouge. Then start sanding with a high grit and little pressure.
It take a lot to get a good, high gloss finish on soft woods. So stick with a satin finish.
