Turning eucalyptus
Turning eucalyptus
Turning eucalyptus
ILYA ZAVORIN
>I am experimenting with bowlturning eucalyptus. The wood is quite green. How fast does it dry, compared to, say, maple or cherry? How much does it move when drying, again compared to other species of wood? Does it have a tendency to split less/more than other woods? Thanks much.
Re: Turning eucalyptus
Dan Oliphant
>There is no direct answer to your question, because there are many varieties of eucalyptus. I have turned a fair amount of several varieties, both green (like cut down within the last few days) and semi dry. Each is quite different. What I have seen is as follows; green eucalyptus is a joy to turn, very stable. Some reminds me of the harder hardwoods, smaller pore structure, other varieties have a larger pore structure, similar to a softwood. I have not noted a lot of movement while drying (DNA then double baged) after rough out. Finish turning leaves a nice surface that doesn't require a lot of sanding.
Ric Taylor
Ric Taylor
>Ilya,
I have turned several pieces from curly and quilted Eucalyptus (not sure what varieties they are). All of my pieces are semi-dry. The wood is not difficult to turn, although it can take some extra effort to get rid of the sanding marks.
On my pieces I have noted some slight movement associated with the curly grain several months after the pieces were finished.
The finish can be spectacular if you get a good piece of wood.
Ric
Bill Hale / The Wood Spinner
>I guess it depends on where it is grown and where you live as to movement and checking. There is one given in that when Euc. is dry it is as hard as %^&* and the flying chips will burn your skin as they come off the tool. Turn it green and test a piece for checking and movement. I have had pieces move as much as 25%. The piece actually became oval.
Good turning and be safe
Bill in CG, AZ.
tm
>Ive turned a few of the eucs too.
I agree with what Dan says.
I scored some really nice Red Ironbark a.k.a. Euc sideroxylon in Nov.
and rough turned a few and painted them with a product called Pentacryl (www.rockler.com)
and so far no blanks or rough turned bowls have checked.
I think movement varies from species to species.
Its gorgeous stuff and worth trying.
tm
Dave Staeheli
>IDKHIKT but I've heard there are 1500 varieties of Euc in Australia, some of which have made it to the states. I've had terrible luck with one variety, a pale wood with lots of cross grain. Lots of pull out when dry. On the other hand, I have turned red gum euc that was just gorgeous, a dark red wood that turned very nice. Biggest problem was keeping it from checking. Untreated wood woud check within an hour. I had to dry it very slow, even wrapping it in cellophane for a couple of months in addition to sealing the end grain. I had no luck with DNA soak. Also it had lots of black pitch pockets which dried up into partial voids. I ended up filling these with coffee grinds and CA glue. I can't wait to get more of it.
I've heard good things about Red Iron Bark.
