Light glare
Light glare
Light glare
Bill Crommett
>This is an urn that I have just completed. It is about 16 inches tall and consists of Cherry and walnut in the body with a red cedar top which I presume will darken with age, and a blackwood finial inspired by Jamie.
I need a critique on he photography.
Re: Light glare
Re: Light glare
Texian
>Bill,
Some thoughts from one also trying to learn:
Shoot from lower angle to show overall shape of the piece better.
Get smooth background without wrinkles (actually, get two, one for me).
The lighting seems "confused". Try one light in front at 45 degrees, and try to bounce some fill light behind the piece. Move lights around, raise and lower, and study the results.
Ok, time for the real photographers to jump in here.
Meanwhile, good looking piece, Bill.
Re: Light glare
Peter Charles Fagg (UK)
Re: Light glare
>You do not say what the light source is but if it is a flashgun you could try putting a piece of tissue over the head of the gun. It softens the light for portraits so I see no reason why it shouldn't work here.
Alternatively make or buy a system of screens in which the piece can sit so that the light is gently filtered through the surround rather than a direct light.
Alternatively try shooting outdoors on an overcast day, that way there will be no direct light on the subject.
Alternatively bounce the light on to the item from a sheet of polystyrene, the stuff used for insulation, a sheet of newspaper works well for portraits for bringing a soft light in under the chin so it might work here also?
Happy shooting, Peter.
Re: Light glare
Re: Bill-shiny surfaces are "heck" to....
Jamie Donaldson
>....to light without bad reflections, and diffusing the light source is my solution. Have you read the Phrugal Photo tutorial posted here on WC or on my web site(jamiedonaldsonwoodturner.com) The lower camera as suggested is better for showing the profile, and reducing the number of lights to only 1 helps with control of the multiple highlights and shadows.
Re: Light glare
Re: Light glare
Bill Crommett
>One light, Jamie says. My photo set-up has five (5) halogen work lights, each filtered through some flimsy white stuff. The reason for the high angle is that my background cloth was designed for small objects, and was too small for anything this tall. Work this over for me, please.
Re: Light glare
Bounce the light
Jorge Castaneda~Downeast Maine
>instead of direct lighting.
Re: Light glare
Re:Do your neighbor's lights dim .....
Jamie Donaldson
>...when you turn all those lights on?? If you check out my set-up you'll save a lot of money on the electric bill next month!
Re: Light glare
Bill Crommett
>Jamie: I started out with one light and kept trying to eliminate shadows with adding more lights -- obviously a failure.
Your phrugal funny box would be good for small stuff, but not for an object of this size.
The lights used to dim when the furnaces in the neighborhood went on, but the neighbors got together and embarrassed Duke into putting in an adequate sized transformer.
Re: Light glare
Re:I don't know what you mean by....
Jamie Donaldson
>.. my "phrugal funny box" but it is 32"Hx44"W and has handled pieces the size of yours amd larger with ease? What were you looking at anyway?
Re: Light glare
Bill Crommett
>Sorry Jamie, It must have been someone else's.
Re: Light glare
Re: Light glare
Texian
>Bill,
One shadow is often ok, as it helps to give depth to your image. But you do not want a bunch of shadows pointing in several directions. Start with one light as suggested and work up from there. Indeed looks like you have massive overkill on lights. Also one highlight, correctly located, can be good, especially if the piece has a glossy finish. Otherwise some of that filtering and bouncing is helpful. Exposure too long with less light? Use a tripod and the camera's self timer or cable release or remote release.
Re: Light glare
Re: Light glare
Texian
>Bill,
If no cable release or self timer, try using a tripod or simply hold the camera firmly on something solid with one hand and press shutter release with other. No shame in shaky. That's what tripods and all this other stuff are for.
