Re: wood movement
Gary Evans Tallassee, TN
>One of the fallacies regarding KD wood is that it is actually dry uniformly all the way through, particularly on wood thicker than 2". Regardless of the MC at the point or points where the measurement was taken, there will almost always be moisture gradients throughout a particular piece of wood; hence movement as you expose previously unexposed wood to the atmosphere.
The other issue is the stresses that build in the wood as it is being dried. When the wood is still in the form of the cant in which it was originally dried, those stresses are balanced through the piece. Once you cut it up into smaller pieces, those stresses can stay in the wood and show up when you least expect them. Ever had a piece of kiln-dried wood pinch your sawblade when you were ripping it? Same principle.
Roughing out to 10% and then letting wood set for awhile is not a bad idea, even with KD wood. KD wood, depending on the MC when you got it, shouldn't have to sit long to equalize with the area where you have it and relax some of the stresses within. Be nice if you could just feed it a valium. 8^]
Gary
