waste block?
Everette Harmon
>Can you use MDF for a waste block.
Thanks
Everette
waste block?
Everette Harmon
Thanks
Everette
No...Use Wood...
Wally Dickerman in Arizona
>MDF won't hold screws and it won't hold together when you part the piece off.
Wally
MDF Waste block => Darwin Award?
Richard Allen
>Using MDF as a waste block will work fine for some turnings. But as Wally has said MDF has some attributes which makes MDF a poor choice for a waste block.
Re: MDF Waste block => Darwin Award?
Everette Harmon
>Thanks for the replys, No MDF.
Everette
jim Miles - Charlotte NC
>Scrap 2 x 4s or 2x6s Spruce-Pine-Fir work fine, Tons of it go to landfill daily from construction sites - they will usually give you all you want, watch for knots checks, splits etc.
Darrell Feltmate
>When I cut bowl blanks or stuff like that, I usually have scrap that is going to the kindling box. Once in a while I take anything large enough to the band saw and cut it into 3/4" to 1" thick slabs at least 3" across. This gets piled in a corner for glue blocks later on. This gives me a supply of ash, maple or cherry blocks at least. I can depend on them to hold screws well and take the glue strongly without worrying about breakage. If any of them look cracked or doubtful, they were going to be kindling anyway. If I want extra faceplates for glue blocks, I just drill and tap a piece and away I go.
