shihodhuaco???
shihodhuaco???
shihodhuaco???
Rick Davenport
>I scored a batch of free wood from Peru that is poorly cut, poorly sealed and lamely labeled.
(no wonder it was free, but I have managed to make some nice pieces with it)
I'm working on a piece right now labeled "shihodhuaco."
I've done a number of searches with no results.
Anybody ever heard of shihodhuaco?
I will post a picture when I am done.
R
Re: shihodhuaco???
Re: Any chance you are suffering from someone's
Al Crandall -NW of Indy-
>http://www.uncommongoods.com/item/item.jsp?itemId=15925
Any chance you are suffering because of someone else's poor spelling? The similarity of the names makes me think this is so. Does your wood look like the wood in the link above?
Re: shihodhuaco???
Rick Davenport
>Thanks Al.
That's exactly what I'm working with.
R
Re: shihodhuaco???
Re: shihodhuaco???
Barry Elder
>Gesundheit!!! Jim King might be around and maybe, being in Peru, he might be able to help you.
Re: shihodhuaco???
Re: shihodhuaco???
Jim King
>I really have a serious question if in fact you have Shihuahuaco. I am the only person in Peru that exports turning blanks and hobby woods. I have never exported it that I remember of as it is a very plain flooring wood and not enough figure for turning or decrative woods. Attached is a photo of the only peice I turned from several years ago before Jaime shot me down for blue backgrounds. Being that you bought it from someone who did not know how to spell the name makes it even more difficult to ID.
Some people also call Shihuahuaco, Santos Mahogany but it is not in the Mahagony family. Here is what I sell on the web site below, I would be interested in a photo and where you bought it if possible sent to my email address.
http://www.exoticwoodworld.com/species.htm
Here is a spec sheet done by our scientest at the U of SC.
Estoraque / Charapilla / Shihuhuaco / Santos Mahogany
The family Leguminosae comprises trees, shrubs, lianas (sometimes with tendrils) or herbs which may be armed; roots often bear nodules containing nitrogen fixing bacteria; hairs simple, stellate or glandulous; stipules usually present and sometimes are modified to spines. The leaves are typically alternate and spirally arranged or two-ranked, rarely opposite; simple or pinnately, bipinnately or palmately compound, rarely with as few as 1 leaflet imitating a simple leaf. The petiole has a swollen pulvinus and is jointed at the base, sometimes bearing glands. The inflorescence is axillary or terminal with the flowers arranged in spikes, racemes, panicles or heads, rarely solitary. The flowers are regular to zygomorphic, anthers sometimes with glands, the annular, ring-like nectary surrounds the base of the ovary; ovary usually oblong and compressed, more or less stalked, with 1, or rarely more carpels, 1-chambered with 1 to many ovules; style long with a single stigma. Fruit is a legume containing seeds in 2 rows along the dorsal suture; may be dehiscent (opening naturally when ripe) along 1 or both sutures, dry or drupaceous, containing 1 to many seeds with smooth hard coat, or seed may be fleshy, brightly colored.
One of the three largest families in the world with 720 genera and over 20 thousand species. This family consists of three major groups that are treated as subfamilies or as independent families by other authors.
Pea family - Subfamily Papilionoideae (or family Fabaceae in the strict sense): flowers strongly zygomorphic (papilionoid), petals imbricate in bud, united at the base, the upper petal (standard) is outside the two lateral petals (wings), the two lower petals are joined to form the keel; sepals usually free. Exceptions are certain genera in the Swartzieae and Sophoreae groups. Stamens are typically 10. Seeds have a hilar groove (unless soft) and are without a pleurogram, radicle usually straight. Leaves are never bipinnate but may be pinnate, or rarely 1-foliolate or simple.
The genus Myroxylon comprises unarmed trees with simple hairs; without stipules and stipels. The leaves are spirally arranged, imparipinnate, with the 5-11 leaflets in alternate positions, and the blade with pellucid lines and dots. The inflorescence is an axillary raceme; the calyx has a funnel or bell shape and 5 shallow lobes. The corolla is white, the standard is much wider than the other petals which are very narrow. Stamens are 10, free or slightly fused at the base, the anthers are longer than the filaments, dorsifixed and shaped like an arrowhead. The ovary is staked, 2-ovulate; the style is incurved. The fruit is staked and asymmetrically winged (samaroid) containing a single seed in the apex. The seed is resinous, kidney-shaped. Only 3 species in Central and South America of which 2 are recorded from Peru.
Myroxylon balsamum HARMS is up to 40 m tall, the leaves, 5-15 cm long, have a round rhachis bearing 5-11 ovate to lanceolate, alternate leaflets which are 3-11 x 1.5-4 cm, glabrous, the blade is not flat, the margin is undulate, base acute to obtuse, tip acute to acuminate. The inflorescence is to 20 cm long; flower is white, 12-15 mm long; the bell-shaped calyx is not persistent and is hairy, 1.5-6 mm long, standard petal is orbicular, and 9 mm wide. The samaroid fruit is stretched obovate the fruit is 6-11 x 1.5-2 cm. The seed is 1.5-2 cm long; cotyledons smooth. Lives in wet lowland forest below 500 m altitude. The aromatic resin is extracted from incisions of the bark and is used medicinally and in perfumery.
Other Common names: estoraque, b�lsamo, Balsam of Peru
Re: shihodhuaco???
Re: Shihodhuaco
Philip F Duffy
>Ron, Fantastic web site. Thanks, Phil
