Varnish and Laquer
elliott
>Wouldlike to knowwhat isthe basic difference? And on woodturning- what gives the highest gloss shine on the wood?
Varnish and Laquer
elliott
Re: Varnish and Laquer
Bill Hale / The Wood Spinner
>One difference is how they lay on the work. Varnish builds in layers and does not melt into the prior layer. It may chip. It is also water proof and will not spot the way lacquer does.
It is my preference for food bowls etc. I use Cabot 8065 spray can sanding sealer. It is a varnish base with UV protection that has been thinned and an accelerator added to speed cure.
Lacquer melts into the prior layer and builds as one layer. This is my preference for decorator pieces that will sit on a shelf and never be used. It can be built up and brought to a very high gloss.
Each has it's place!
Good turning and be safe
Bill in CG, AZ.
Re: Varnish and Laquer *LINK*
Brian Hahn in SW Wisconsin
>Lacquer dries and hardens through solvent evaporation, just like shellac.
In varnish, the resins react with air to cure into a hard finish.
"Russ's Corner" (in the articles section of this site) has some very good information.
Here's a link to Russ's treatise on finishing.
Finishing Secrets
