Micro mini goblet
>This is the last in the mini series. The big ebony goblet is 7/16" and about doll house scale. The micro mini next to it is .024" tall or about as tall as 6 sheets of paper.
Micro mini goblet
Re: Micro mini goblet
>Here it is on a Dime with a pin head next to it.
Ron in Drums PA
>Did you use the 80 grit gouge on this one?
Kidding aside, you should contact "The Guinness World Book Of Records" for the smallest turnings completed on a full sized lathe.
John, are you going to add...
Cyril Griesbach
>this one to your little square magnifing box with the others?
How do you sign them?
steve antonucci
WHAT?
richard jones
>No loose ring? :)
Very nice, I could never see something so small to turn it. Do you use any magnification headgear?
rich
mike hunter
>John ... I like that ring. I am impressed!!
>I plan to contact them. It looks like a lot of paper work but might be fun.
Re: John, are you going to add...
>It is going in micro goblet box. I also have a small goblet box. I love to watch people looking in and seeing the yellow heart goblets which are much bigger. Then all of the sudden they will see the little one. That expression is worth doing it.
very carefully :)
Re: WHAT?
>I use a stereo microscope I got off Ebay for $35. I had to use the microscope to grind and sharpen the tools as well. It took quite a bit of jury rigging to make a stand and have micrometer adjustments to get the scope in the right position above the goblets.
>Mike I pulled out a curved scribe that I had and it looked really sharp. I put it under the scope to cut the ring and it was huge. I had to touch it up with an ultrafine diamond hone and then green compound on leather strop to get it sharp enough to undercut the ring.
The inside of the goblet isn't very clean. I needed a super small Hunter tool. :)
John Kyler
>Do you use tung oil (like Julio Marcolongo)?
Ok, so I take it you drink less with that little one? Or you do more curls?
Nice, but a PM for that small. I have the PM4224 if size matters I might be able to go smaller... NOT
John
Jim Terry
>John, That is amazing! If I were ever lucky enough to do something like that I would probably drop it in the shavings under the lathe when I parted it off.
Don't sneeze around it!
Steven Kubien
John Kyler
>Just to think.....
Many of us when we have a catch (well I never dooooooo :)
But they are bigger than the whole project John makes!!!
Again nice work.
When I get a catch you can't see it. :)
