Cup center "New to turning"
Wayne Carson "TX"
>what is a cup center used for. I got several centers with the lathe I bought used. I know what the live center is for but have no ides what the cup center is for, is it used on the head or tail??
Re: Cup center "New to turning"
Bill Howatt
>It is a common woodturning center used in the tailstock. It usually has the point with a cup around it. The idea is the point locates the centering but the cup keeps the point from being driven into the workpiece too far and possibly splitting it. Some people who have a center that is the typical metalworking style, all point, no cup. put a washer over the point which limits its penetration into the end of the workpiece.
You do not have to have a point to use the cup by itself. Is yours a live or dead center? The live has a bearing so it rotates with the workpiece whereas the dead doesn't rotate. If you have a dead center put a drop of oil on it when you use it - at least we always did in Grade 8!
Bill
Dennis Yoder
>I was taught to use it in the headstock as a drive center. The advantage is that it allows the wood to stop if you get a catch. It is particularly useful for spindle work and for beginners to avoid dangerous catches. Dennis Y
Bill Howatt
>yes, you can use it for that purpose as well. I used to use one that way but I no longer bother.
Bill
Russ Fairfield
>The problem with using the cup-center to drive wood is that it takes more tail-stock pressure than I would want to use, just to get enough friction to turn the wood. A better way is to give it some bite by filing notches in the rim of the cup, and make it look more like a Steb-center.
Wayne Carson
>I have both but use a live center most of the time (all the time). I haven;t had any problem with the centers I use just didn't know what it was for.
Re: Cup center "New to turning" *LINK*
Jerry Whitaker
>Wayne....check out this website: www.swaturners.org This is a Texas woodturning symposium scheduled for October 17-19 in Waco, TX. There is already a little bit of information on the site about the symposium. Keep checking regularly for more information as it develops. Since you are new to turning, this symposium will blow your socks off!!!
SouthWest Association of Turners
