shop-made HSS hook tool *LINK*
Ken Grunke from SW WI
>I made this tool about a year ago and have put quite a bit of use into it. Starting with a 3/8" square HSS machinist's toolbit, (or whatever size you may have), an angle grinder with a 1/4" reinforced metal grinding wheel, and less than an hour's time, you hopefully end up with something like this--more pics and short story on my site linked below:
My shop blog: HSS hook tool
Re: shop-made HSS hook tool *LINK*
Steven Antonucci
I "forge" mine
steve antonucci
>I make mine from O1 round steel rod that I heat with a torch and smash a flat spot. Once I have the flat, I grind both sides flat on a belt sander and then reheat and bend the hook. Quench in oil to harden.
Start to finish, 10 minutes if I set up for it
How did you find working with the preharden bit? Is it better than O1?
Cyril Griesbach
>Very interesting, Ken. I also checked it out on your blog. Great ides on how to round those cutters. My way is much more difficult. Thanks for posting this.
Cyril
Re: I "forge" mine
>Steve, I've made the Alan Lacer forged design also--Lacer demoed for our club back in '03, I think it was and that's when I made mine. Great design, and O1 is a good steel.
This one is M2, and it is tough to grind. The best reinforced wheel I've come across so far for a portable angle grinder is Norton's "Norzon" wheel, for Metal/Stainless, with a blue label. Cuts HSS like butter. (well, sort of).
Re: hey Cyril...
Cyril Griesbach
>Giving it serious consideration, Ken. Awaiting Carol's decision.
Re: hey Cyril...
Cyril Griesbach
>Ken, I just emailed Aaron and we're planning on being there.
Cyril
