Moisture Meter
elliott
>Do any turners use a moisture meter? If so what brand/type?
Moisture Meter
elliott
I use my face...
steve antonucci
>Seriously.
If the wood feels cool against your cheek, it's still wet.
Try it.
Steven
Re: Moisture Meter
Mike Jones, Redding, CA
>I need all the clues I can get. My meter takes guessing out of the equation, and, has helped me learn how wood drys. I used it more as a beginner, but still rely on it when working with new or unfamiliar wood species.
Re: Moisture Meter
Keith Newton------WebKitFormBoundaryZPoA43GU3Ns+ew
>Elliot, I have two of them, pin, and pinless, but I have never use either of them for testing my turnings. But then I normally do all of my turning green, and don't put them back on the lathe after they are dry, so knowing the MC has never been information that i needed.
The problem with a pin type, would be dealing with the holes where you stab the pins in. Then with the pinless, I am not sure if it would read right when it doesn't sit on a flat surface. Also if it is thinner than about 1/2" may be an issue also.
Just a few thoughts. But then maybe I don't understand what you are needing the information for, or what the finished product is like.
Re: Moisture Meter
John Scheideman
>I have the Lignomat and it has pins. The pins are not a problem. You really can't even see the holes. I like mine very much and use it all the time for rough turned bowls that I am drying. It is made in Portland, OR and the phone number is 1-800-227-2105. They have several different models.
John
Re: Moisture Meter
>I use the pinless type, not for turnings but to check wood I might want to turn. The pinless type needs a flat spot to work.
Re: Moisture Meter
Ed Karch
>I have a pin type but seldom use it except for flat work which I seldom do anymore.
Re: Moisture Meter
Doug Turner
>I use one I picked up at WoodCraft Supplies on sale for $30. It is a combination stud finder, moisture meter etc. I tested it on a dry piece of wood and it read 6% and saome fresh cut bowl blanks which exceeded 36% so I know it works. I use it primarily to verify a bowl blank is dry before I put it on the lathe (especially if I forgot to date the blank). I still rough turn and then season for a couple of weeks before final turning if I don't want the bowl to move at all.
