Removing green wood sealer
ILYA ZAVORIN
>I have a couple of green logs that I had treated with green wood end sealer. Is it possible to remove it without cutting or scraping the wood, i.e. essentially leaving the logs intact? Thanks.
Re: Removing green wood sealer
Steven Antonucci
I'm guessing no...or very impractical.
steve antonucci
>I cut my logs longer than the width by a couple of inches just to get around this problem -then zip the ends off with the chainsaw, sealer and all.
Steven
Hi Ilya...
GaryG in MD
>Green wood sealer is a water-based wax emulsion. When it dries, you just have a waxed piece of wood. On end grain, I suppose the wax soaks in for some unspecified distance, depending on the type of wood.
I would say to burn it off with a torch, but your post sounds like you want to save every millimeter. Maybe it'll be a piece in your new black on black series! ;-)
FWIW, wax is permeable to water and many other solvents. That's one of its problems. We'll need Russ or some other finish experts to chime in here, but I would expect that you could just put the right finish on right over the wax. Then you wouldn't have to wax it later! Sort of like "eat dessert first..." ;-) I'll bet there's at least one finish that will dissolve the wax and effectively ignore it. But what do I know?
Tell us your result at the next meeting -- it will be interesting for all to hear.
...Gary
Re: Hi Ilya...
Ilya Zavorin
>Hi Gary. Actually, here's the reason why I want to do it. The logs are silver maple. I've had some success getting other maple logs nicely spalted in my compost bin. If I come to the next meeting, I'll bring a bowl that I had made out of one of those. These particular logs I treated with the sealer, but now I want to remove it and try spalting them. I am not really trying to save every inch of wood since the logs are pretty big. I thought that there might be an easy way of removing the wax other than taking a chainsaw and cutting a few inches of the log at each end. But from what you've described, it seems that it would be easier to just use the saw. In any case, thanks.
Re: Hi Ilya...
>My experience is the wax sits on the surface and penetrates very little (or none) into the wood. (Remember, the thick emulsion is applied when the wood is already saturated with water.)
I think you would only have to remove a tiny bit of wood to remove enough wax to allow spores to enter. Perhaps passing a chain saw back and forth over the end grain would do it. I would avoid heating to remove since I can imagine the wax liquefying and being drawn into the wood.
Re: I'm guessing no...or very impractical.
tm
>I like the chainsaw idea. Here's another option. I do faceplate turning often. When I prep a waxed blank for a glue joint to a wasteblock I use a round wirebrush chucked in a drill motor.
It takes the wax off quickly and textures the wood a little
for a better glue bond.
Cyril Griesbach
>This came up once before and boiling was the answer that time. Never tried it cuz I just cut it off.
