Cherry Burl HF
Cherry Burl HF
Cherry Burl HF
Cyril Griesbach
>I haven't posted any work for some time, mostly because I can't seem to take a decent photo in spite of trying to follow all the advice available on turning forums.
This HF is about 5" x 4" with a natural edge. All comments are welcome.
Cyril
Re: Cherry Burl HF
Re: Cherry Burl HF
George Van
>This is a great looking piece of cherry and appears well finished Cyril. It appears to be a natural edge opening? I will let the experts advise on the photo but it looks to me like you could use more light to the front, maybe move the HF back and zoom in. I would prefer a more moving curve even if I had to shorten the form a little. Above and below the shoulder appear to me to be a little flat. Thanks for posting, George
Re: Cherry Burl HF
Steven Antonucci
Same a George's advice...
steve antonucci
>Sometimes tough to cut a burl into shavings, but I think the shapes got a couple of flat spots. I might have shortened the pot too to put the visual weight lower.
Steven
Re: Cherry Burl HF
Re: Cherry Burl HF
Cyril Griesbach
>Thanks, George and Steve. You can't imagine how many times I looked and felt this to see that there were no flat spots. Maybe it's the photo and then again it could be my old eyes. I ran my fingers all over it with my eyes closed to feel for flats.
Re: Cherry Burl HF
Re: Cherry Burl HF
Jerry from Lapel In.
>Cryil did you use the red or green rigg .
Re: Cherry Burl HF
Re: Cherry Burl HF
George Van
>Cyril, try a small straight edge, I use a piece of Formica sample, and roll it up and down the form. It will show you flat and also very slow curves that can be perceived as flat. I like it because it also gives me a little feel for the speed of the curve while I am rolling.
As for height and form, Wally D. suggested that I take my pieces off the lathe and observe near and from a distance. One of the best pieces of advise I was given. I have a raised viewing stand (pail upside down with board on it) that sits on my workbench which brings the piece to eye level.
Re: Cherry Burl HF
Re: Cherry Burl HF
Cyril Griesbach
>Jerry, I used the red one on this
George, I had this one off the lathe several times doing just what you suggest. I will, however, give the formica procedure a try. Thanks for the tip.
Re: Cherry Burl HF
Steven Antonucci
One more trick
steve antonucci
>Close your eyes and rub your hands over the piece. Your hands are sensitive to a change in radius or flat spots more so than your eyes.
