new LARGE bowl
new LARGE bowl
new LARGE bowl
chris rolke
>it is made from 5 10' 2x4 cut and laminated together
making a 30" square that weighed 53 lbs
when i cut the corners off i dropped it down to 42 lbs and that is what went on my jet 1642
final weight is 13 lbs diameter is 28 1/4"
Re: new LARGE bowl
2nd pic
chris rolke
Re: new LARGE bowl
3rd pic
chris rolke
Re: new LARGE bowl
4th pic
chris rolke
Re: new LARGE bowl
Re: new LARGE bowl
George Van
>What a great job handling that larrge of piece Chri. I think the best photo is the one with the smile!
Re: new LARGE bowl
Steven Antonucci
A lot of work for a sled :-)
steve antonucci
>Don't you have a Walmart close by?
Pretty cool what you can do with an outboard setup. Looks like you might do another one, huh? Start with a 2x10 so you get some depth?
Steven
P.S. Did you run them over a jointer before glue up?
Re: new LARGE bowl
Re: new LARGE bowl
Bill Hale / The Wood Spinner
>Great job Chris. Did you jointer the edges and what type of glue did you use ?
Good turning and be safe
Bill in CG, AZ
Re: new LARGE bowl
Re: A lot of work for a sled :-)
chris rolke
>yea its a lot work for a sled
no i did not join or plane them prior
i dont knwo about another one
max rpm was about 325
Re: new LARGE bowl
Re: new LARGE bowl
chris rolke
>no joining just careful selection from homedepot
and regualr titebond glue
Re: new LARGE bowl
Re: new LARGE bowl
Norm Smith
>Chris , Both the turning and cute little guy look great. Do you find that outboard tool rest stable enough??
Norm
Re: new LARGE bowl
Re: new LARGE bowl
chris rolke
>the outboard rest does work pretty good
