Turned Lamp
Turned Lamp
Turned Lamp
R Acuna
>Here is a lamp made from HD cabinet ply, stacked and glued rings then hollowed out to 1 inch walls for weight balance. Aluminum plate 1/2" on bottom and 1/4" on top. Six sprayed coats of Deft Laquer Satin, then buffed with wax. The shade was made with lime green silk fabric. Not to intricate in the turning realm but I like the overall look. Cheap and easy. Thanks for looking. R
Re: Turned Lamp
Steven Antonucci
That's pretty nice!
steve antonucci
>I think that is impressive to say the least. The base is a great shape, but I think the top might be too tall for it. I would have gone for a lower, "funnel" shaped shade.
How many sheets of plywood did you use? 1/4? 1/2?
Steven
Re: Turned Lamp
Re: Turned Lamp
Walt Didesch
>I agree with your thought on the overall look. I think the shade sets it off.
Walt
Re: Turned Lamp
Re: That's pretty nice!
R Acuna
>Your right about the tallness of the shade. However this pic doesnt show true perspective. The shade is the same width as the widest part of the base. I used 3/4" ply throughout. Luckily I like the shape of the base more because the shade can be remade alot easier. I had a little trouble with the transition from the 1/2 alum on bottom into the ply. The difference between hardness made it hard to get a smooth curve over and follow the line I wanted. Thanx for looking and the feedback. R
Re: Turned Lamp
Beautiful form!
Molly Winton
>How did you deal with the voids in the plywood? Did you fill them after achieving the form you wanted?
Re: Turned Lamp
Re: Beautiful form!
R Acuna
>I used Elmers Carpenters glue in the small flat tub. It is water based so I thinned it to toothpaste consistency and put it on with tile sponge. Coated the whole thing completely. Let it dry and took my 9inch sander with a 6inch soft pad and went at it. It sanded in no time. I dont think anybody likes sanding. I use a 220 pad. R
Re: Turned Lamp
Thanks for this
Steven Kubien
>I really like this. Plywood is now definately on my to-do list.
Thanks,
Steve Kubien
