veritas scraper burnisher
woody vt
>Does anybody use the Veritas scraper burnisher? If so, what procedure are you using? I follow the instructions that came with it and I am having so-so results. Any advive, such as scraper prep before burnishing, amount of pressure used, # of times running it over the rod, would be greatly appreciated. Thanks.
Re: veritas scraper burnisher
>I use one and I think it's great. I don't know where my instructions are so I can't say if the method I use is the same as recommended.
I sharpen the scraper with a Tormek to usually about 80deg or so, then hone the top surface flat with a medium diamond "stone". (an important step) With the burnisher screwed to the workbench, I burnish using the pin with the least taper, using the straight pin as a fulcrum. I use a fairly hard force but it's difficult to describe the amount of pressure. Usually one or two passes over the pin does the trick. I feel the "burr" with my finger to see if it's enough.
For me, this little device puts the most uniform cutting edge on a scraper with the least amount of effort and skill needed. BTW, the edge is so smooth it cuts very well and lasts much longer than a burr from a grinder.
Fog Tanner
>I use much the same procedure as John, except I use the fine grit side of my Tormek to hone the top flat. When using the burnisher, I will vary the amount of pressure depending on how much of a "hook" I am looking for.
Unlike a burr, which is a fragile wire edge, the hook off this tool is a cutting edge and much more agressive. It does take some getting used to and a lighter touch. Also the reason I vary the amount of hook.
It is similar to the edge on a cabinet scraper. If you don't want to buy the burnishing tool you can get the same edge by placeing the scraper in your vise and using a the shank of 3/8" gouge to roll the edge the same as on a cabinet scraper. But, the burnishing tool is much faster.
Fog
