Micro-Mesh Sanding Pads
elliott
>Would like to knowif you can use these pads on all wood turnings for a finer finish
elliott
yes
steve antonucci
Re: Micro-Mesh Sanding Pads
eaglesc
>Don't waste your money on "pads" MM can be purchased at international violin in 6x12 sheets and use your own backer.
The stuff lasts forever!
No
Brian Hahn in SW Wisconsin
>I've tried Micro-Mesh a number of times and I have always been disappointed. I can get a superior finish using regular sandpaper, either waterproof aluminum oxide or silicon carbide. Both of theses are available to 2000 grit.
On hard plastics like acrylics and polyester, I'll follow with an automotive polishing compound. This gives me a far better finish than Micro-Mesh.
Re: No
elliott
>where can you get them at
Try Abralon Pads
Bill Clark
>I've been experimenting with Abralon pads. They are available in grits up to 4000. I use them for the final polishing (fine sanding) prior to applying the finish. Cindy Drozda highly recommends them. They are expensive but they do work well for that final sheen. They are available from Craft Supplies.
Sources
>Woodcraft has Norton wet-dry through 2000 grit. They claim it is aluminum oxide, but it sure looks and acts like silicon carbide, and it doesn't look at all like the Norton aluminum oxide paper I got from McMaster-Carr. (The sheets and package don't state the abrasive type.)
McMaster-Carr (www.mcmaster.com) has aluminum oxide through 2000 grit, silicon carbide through 1500 grit, plus "Microfinish" sheets in silicon carbide and diamond.
Re: No
George Van
>Brian, I have 3M� Imperial� Wetordry� Paper Sheets up to P2500 grit and like you get good results when I want a fine finish.
