The beauty of digital...
steve antonucci
>Is the instantaneous feedback you get!
I shot this on Shutter priority somewhere around 1/60-1/80. I believe that the camera was set at 100 ISO, and the F-stop might have been 5.6 (chosen by the meter in Shutter priority).
As far as the telescope goes, my Orion 8" dob is 1200mm with a 25mm eyepiece. I shot it handheld with the camera up to the eyepiece. I was bracketing up and down a stop to see if it helped. The moon is so bright, it helps to underexpose it a bit or you lose details.
I may try to cobble together a mount or just buy one to see what effect it had vs. hand held. If I raise the ISO to 400, I'd probably shoot it at 1/200 or so. You can see the results instantaneously, and adjust up or down if necessary.
Right now, the biggest issue I have is that the eyepiece is 1.25" and the camera lense is much bigger. Aligning the lense to shoot through that tiny bit of glass is a bit of a balloon squeeze. Essentially, you need to have the center of the lenses aligned and on the same axis or it gets soft on the edges.
Hope that helps.
Steven
