Bench Grinder
elliott
>What type of bench grinder do most of the woodturners use with the wolverine system. I know they recommend high speed.
Bench Grinder
elliott
Re: Bench Grinder
Allen Neighbors
>I bought a Delta variable speed. I run it on the slow speed (1725) all the time. I have 80 Grit and 120 Grit wheels, white and pink, respectively.
I paid 170 or so, at Home Depot, on sale, a couple of years ago.
Any 8" grinder will do... Single speed is cheaper... could have had an extra 100 for more tools! :))
Re: Bench Grinder
John Leonard
>I use a Woodcraft 1725 rpm that I got on sale 5 years ago for about $90 with two white wheels 80 and 120 if I remember right. Had a problem with the switch about 6 months ago. Blew out the dust and works just like new. John L.
Re: Bench Grinder
>Same here. I'm perfectly happy with my Woodcraft Grinder. I put a 1" wheel on the left and 3/4 on the right. Both are 100 grit.
Re: Bench Grinder
Ed Karch
>Same grinder here.
Re: Bench Grinder
Doug Thompson near Cleveland
>One more vote for the Woodcraft 8 inch SLOW speed grinder.
Re: Woodcraft slow speed also.
Re: Bench Grinder
elliott
>any feedback on the Steel City variable speed grinder
Re: Bench Grinder
Ken
>Hi I just got the Delta slow speed 8" about a mo. ago and really like it.AS for most turners that I know usually recommend a slow speed and not the high speed for sharpening turning tools chisels and so on.
Re: Bench Grinder
Bill Neddow
>I have had one for close to two years now, and really like it.
Woodcraft slow speed dito!!!!
The MountainMan
Re: Woodcraft slow speed dito!!!!
Bill Blasic
>I use the Woodcraft slow speed and the Delta slow speed, both work fine.
Re: Bench Grinder
Larry In Lima
>I'm using a Baldor 7" 1800 rpm with Norton wheels. Works very well. Would have liked to have an 8", but way too much $$, and I came across a good deal on the one I bought.
The Wolverine system is great too - Larry
Re: Bench Grinder
Bruce McElhaney, Spring Lake, Michigan
>I have a Delta 1750 RPM 8" grinder and like it, especially with Norton Blue wheels in the Wolverine setup. I also have a Baldor 6" 1750 RPM grinder but rarely use it anymore although the Baldor definitely runs smoother. Maybe I should sell it?
Greg Haugen
Re: Bench Grinder
Pete in Holland, MI
>Woodcraft grinder here. With the white wheels, once they start to get some dark streaks on them, that is an indication that they are getting dull. Dress the wheel to re-sharpen it with a diamond dresser. HUGE difference in how a dull & sharp wheel cuts, and doesn't burn, tool bits !
Re: Bench Grinder
Peter Hyde
>Put it side by side with the Delta variable speed and can you tell the difference? Oh yes the labels :-) I like mine and the wheels that come with it are pretty good as well. The SC was $120.
Re: Bench Grinder
robo hippy
>I have a Baldor 8 inch, and a Woodcraft slow speed. The Baldor runs so smoothly that you almost can't hear it run, and I don't have to bolt it to the work bench. The Woodcraft works fine, but the only thing better about it is the price.
robo hippy
Re: Bench Grinder
Dick Hines
>I am useing a Pachard grinder. Packard was a devision of GE years ago,like 50,. My grandfather used it to grind saw blades in the mill. It is a high speed grinder. I figure it is was good enough grandad it is good enough for me.
I use a 100 grit wheel and also have a 80 wheel. With the HHS tools, Doug Thompsons, and a grinding jig I don't get any blueing.
Re: Bench Grinder
Fog Tanner
>I don't own a Wolverine system, but I do have a dry grinder for use with my Ellsworth jig. It is the 8" single speed Delta, slow speed tool room grinder. It weighs around 100lbs and was $170 when i bought it. It has a 120 grit and a 60 grit wheel on it. 60 for scrapers and the other for the Ellsworth grind on my Thompson. For all the rest of my turning tools I use a Tormek wet grinder.
Fog
Re: Bench Grinder
elliott
>well i decided to buy the 8" steel city variable speed for great price of $110 with 5 yr warranty.can't beat that
