Three phase machines
Doug Thompson near Cleveland
>Did you ever see a machine that would be perfect for the shop but after looking at it you found out it ran on 3 phase. Machines like this are made for the industrial world because it�s more efficient to run a motor off this than single phase like we have in our homes. There is a way to convert one of these industrial machines to run in your home shop.
There are two groups of machines for sale. The first is a machine that is currently running so you could see that everything is working order, you will pay more but there won�t be any surprises. Even if the machine runs well it still has to checked for wear, the ways and the spindle bearings must be in good shape before it is purchased, these are costly repairs. The second group is found at a machine dealer, they are not under power so there is no way to see them run but because of this the value is reduced to bargin basement prices. These are my favorite group to look for but remember there is a reason these machines are not in a shop running production.
. Before you purchase a machine that is not running you need to ask yourself a series of questions. What if parts of this machine don�t work how are you going to fix them and how much will it cost, do this before a machine is purchased. I found this one at a local used machine dealer to show as an example how this was done. This older CNC production lathe was at a local dealer, I made a list of each part that might need to be replaced then researched the price on the internet. The list for this machine started with the motor that has to be replaced because it�s only 1 hp so a 2 hp motor is about $300; the CNC controller is almost guaranteed not to run so I planned to spend $1,000 to build a new one. Other parts that might not work are the servo motors at $200 each and a ball screw that is around $200 from ebay. The spindle has a simple arrangement of 2 sealed bearings which is no problem. This was purchased for $399 which sounds like a deal but remember it wasn�t running and I have no idea if it will or not. The total cost for this project should be $2,000 to $2,500 which is a good price for a small production CNC lathe.
Re: Three phase machines
>You bought it how do you get it home? Industrial machines are made from cast iron, steel plate and lots of it. They start about 800 pounds for a small surface grinder to a small vertical mill around 2,000 pounds. This lathe weighs in around 1,500 to 1,800 pounds; much of the weight is in the frame that supports it. For $200 I found a company to deliver it, this is done with a tilt bed truck and the lathe was slid off onto the ground. To move it the last 20 feet I used an engine hoist to lift it off the ground and the driver and I rolled it into the shop. A $50 tip was given to the driver because it�s not his responsibility to do anything more after the machine is on the ground.
With the machine in the shop it�s time to find out what you really bought. This is the time to examine every inch, remove all the covers and with a good light look at it close for any problems. This is also the time to see if the motor was wired for high or low voltage. If this was wired for low voltage it would run off a converter but this machine wasn�t.
Machines are wired to run off 3 phase for one reason only because a motor runs efficiently and the motor is the only device that uses 3 phase that is wired to the machine, all the other controls in your electrical panel run off 110. You need an electrician to change this panel over to single phase, remember do not open or work inside the panel unless you are a qualified electrician, this will kill you. The basic panel works like this, 3 phase is brought in run through the fuses then to the motor starter, when the button is pushed on the operator�s panel to run the spindle motor the starter allows the electricity to flow to the motor. Two hot leads run from the fuses to a transformer which changes the voltage to 110, this controls all the relays which includes the motor starter in the panel.
I have a special wire made up to test a panel so I hooked it up and started to check out the electrical controls. To my surprise I pressed the start button the relay was brought in and we had lights on the operator�s panel. The CNC controller also lit up with a screen full of beautiful writing. To test the controller and the servos I started to jog each axis then programmed some simple G code� it worked. This alone saved $1,000, money that could now be used to upgrade the controls.
Because this was a unique production lathe I decided to find out more about it. The CNC control had a company name that I heard of before but never used so I called them up. The owner of the company remembered building the lathe about 15 years ago, this was a special order production lathe and in use until the plant was closed and the machines auctioned off. The CNC control is still being manufactured so I sent the main control board back to be upgraded to control the spindle rpm�s and a new manual was purchased.
>The conversion.
First I used a wheel puller to remove the pulleys then removed the old motor, the new motor was located, four holes were drilled and taped then the new motor was installed. Total time was 1-1/2 hours. The next step is to mount the VFD, a bracket was made that could be attached to the VFD so the sealtite used to protect the wires could be held in place. The sealtite was then run from the main electrical panel to the VFD and another from the VFD to the motor. Total time 2 hours.
Wiring should be done by a qualified electrician. Three phase is setup with 3 hot wires and a ground, single phase 220 has 2 hot wires and a ground. In the panel the third hot leg is removed along with the transformer. Power for the spindle motor is from the motor starter to the VFD then on to the motor, this will allow the motor to be controlled from the operator�s panel but most importantly the emergency stop button will shut down the entire machine including the spindle motor. The VFD will give the motor variable speed but I ran a wire from the CNC control to the VFD so the program written will control the rpm�s plus start and stop the motor.
Each axis was checked for backlash every 6 inches, how much backlash in each ball screw has to be known before a program is written so the program can compensate for it, this machine was close. Writing a program for a CNC is done with a machine language called G code, it�s a simple way to convert a drawing to something the machine can understand, this is 100% math that needs to be checked and doubled checked before a program is run. First I started with each axis moving slowly a couple inches at a time and then lines were added to the program for another move until I felt comfortable with the machine. Now the spindle was turned on and off in the program, Testing was done with the spindle belts removed so the belts were installed and the spindle rpm�s were checked.
Tooling
This didn�t have a chuck installed so the options available range in price from a low of $100 up to $1,000 I decided to purchase a mid-priced 3 jaw, 6 inch chuck that should suit my needs for a long time. The tool holder is a standard quick change that I had already.
Here we go
The machine is now setup to run off the operator�s panel, the master start button is pushed then the spindle on button to bring in the relay; the only thing to do is hit the cycle start button. With a hand very near the emergency stop button the cycle start button is pressed� the spindle turned on, the carriage cycled then the spindle shut down. That was the goal! Will this save time� not really but it sure beats a manual lathe on repetitive production runs.
Lathe - $399
Delivery - $250 including tip
Upgrade control board and a manual - $275
2hp 3 phase Motor � $300
VFD - $400
New lathe chuck - $400
Total cost; $2024
In closing
Three phase machines are another option for your shop and you can see from this example they are not difficult to change over to single phase. This could have been done with a simple motor replacement or replace the transformer and run it off a converter or install a VFD, the list is endless. The total time to physically convert this machine over was less than 6 hours; the planning stage was twice that so take the time to develop a good plan before you start.
The next machine to be done will be a manual horizontal mill that will be turned into a CNC from scratch, this will involve installing new ball screws, servo motors and the CNC control I�ll build from scratch so it runs from a laptop.
Bill Blasic
Bill Blasic
>Thanks Doug that was very interesting, you obviously know your stuff.
Bill
>Thanks Doug. I have had to pass up many good machines that the University junked because it was simply too much of a gamble for a non machinist to try. The main problem was simply getting it into the shop but I also worry that I might not be able to properly trouble shoot or repair the problems. I have rebuilt several wood lathes but metal lathes are a different ball game.
I have started my metal working rebuild with a used Smithy. I felt this wouldn't be a huge amount of money lost if I'm not successful and it's backed by a company with a known reputation so I can feel free to call to get info and new parts. As a new machinist I'm still learning to adjust all the tolerances and little problems but expect to have the machine running accurately very shortly. then I will be installing a new motor with VFD.
I'm hoping all this experience will help when I do find the big metal for a good price.
Barbara Gill, Remlik VA
>Another consideration is if the part will be available. A number of years ago we bought a double drum oscillating sander from a cabinet shop that was upgrading to belt. We got about 6 good years and then the flexible couplings went. We found out that they were no longer available. It didn't pay to re-work the ends of the drums to accept the type of flexible couplings now available.
Steven Antonucci
It doesn't look like 1500#
steve antonucci
>The local mill up the road from me has some industrial planers running on 440V. They can suck a 1/4" pass off of a 20" wide board without even a thought.
Big iron is cool...
Thanks for posting.
Steve
Jerry from Lapel In.
>I am running the following 3 phase machines with no problem and have bought new 3 phase motors(2hp) for $50.00 on the Internet( what cost is shipping). I am running the following machines Laguna cnc mill, Bridgeport mill, Boyer Schultz grinder, Kent hyd. surface grinder , a 10in and 13 in South Bend metal lathe and one Powermatic 4224. The secret is to get the proper VFD set up or rotary phase converter set up. I am running all of this on a 100 amp.circuit but not all at the same time, I like 3 phase with a VFD because I gives me a variable speed control.I have found a lot of good deals on 3 phase machines .
Bill Grumbine (Kutztown PA)
>I don't know Doug, tubular ways. Are you sure that thing doesn't say Sears on it somewhere? ;-)
Bill
>John,
The weight is a problem but smaller mills, lathes or grinders can be moved without much trouble if you can get it loaded on a truck. A towing service with a tilt bed truck is enough.
Barbara, there are many manufactures to look at for spare parts, Ebay is a very good place to look. This lathe had a bad encoder, the new price was $250 but I found one on ebay for $80.
Jerry you see how easy it is and the price is fair. Hey you must be a machine repairman by trade! You did mention a brand, South Bend lathes I bet they made a million of them because they are everywhere and at a good price. I did pay to much for the motor and VFD, without time to look I went straight to Grainger.
Bill, this lathe sure does look different with the linear slides (almost like the Craftman LOL) This was custom made for Valenite, maker of carbide insert tooling.
Re: Three phase machines *LINK*
Stephen Mushinski
>Doug,
A good place to start and maybe end for VFD is :
http://dealerselectric.com/
Confused this morning
wilbur
>For a moment I thought I was on the OWWM forum. :@)
