Dying help needed.
Dying help needed.
Dying help needed.
Cyril Griesbach
>I've got an experiment going with dying a small shallow bowl/plate. I turned it from 5/4 kiln dried Mahogany and intended to dye just the inside and have an oil finish on the rim and back. After sanding to 600 I applied Fiebigs (sp) leather dye to the interior, let it dry and applied another coat of dye. Much to my surprise the dye blead through to the back side so I had to dye the whole piece. OK, it's an experiement right?
Now some questions:
Should I have applied a sealer to the wood that I did not wish to dye and if so what? I mostly use Danish Oil and Beal buffing for a finish.
I'd also like to experiment with liming wax on this one so should the wax be applied over the dye or should I oil it first and then apply the wax?
I'm going to try to be in on the chat tonight which is to be centered on issues like this but I'm hoping for some info from the group as a whole.
Thanks,
Cyril
Re: Dying help needed.
Dr. Kevorkian?
Jim Rutten
Fog Tanner
>I use a lot of Aniline and fabric dyes. You will get bleeding if the wood is thin or porus. I do dye some pieces different colors on the inside and outside, but not at the same time. I dye the inside and finish it, then do the outside. If I can't correct the bleed through, then the outside is the same color as the inside. If it is going to be limed, then small pin sided places will be filled with liming wax and not seen anyway.
I turn a number of Ash pices which get dyed and either limed or patinated. If you want to do either, the process is the same only color of the wax changes. After dyeing, I use either shellac sanding sealer or 1lb cut shellac to seal the dye. You don't want to fill in the grain, just seal the dye from lifting. Lacquer base sealers tend to lift some dyes, so I don't use those.
After the shellac is dry you can go about the liming or patinating. I prefer doing it on the lathe, but have done it off. The lathe is much faster and smoother. You rub the liming/patinating wax over the area, working with and across the grain. The idea is to fill the grain and have a thin "see through" film covering the piece.
Depending on the wax used, after about 5 or 10 minutes you can remove the wax. I use Liberon Finishing Oil for the finish and removing the wax. I have used Varathene on a blue gouge handle that was dyed and limed, but it left the handle with a purpleish tint. If it is a bowl or platter, I take a Viva (has to be Viva) paper towel and make a pad. I put a small amount on the pad and with the lathe turning, I wipe across the surface. If it is a larger piece you will get part way across, then you go to a clean place on the pad and repeat from where you left off to the edge. For the tool handle I worked from one end to the other, the same as you would if applying Bees Wax.
After the finishing oil "sets/drys/cures" you can apply another coat or two. You don't want to apply more than the one coat to remove the wax so as not to pull any more wax from the grain. One thing I have noticed is the liming wax will blend in with the finish and make the piece brighter. The patinating wax will make the piece darker.
Jan Sanders has both a video and book on dyeing and both are very good sources for imformation. You just have to adapt her methods to where you live. She is in England and her drying times are different than here in Texas. But the techniques are basicly the same.
Fog
Mike Stafford
Mike Stafford
>Cyril, tonight's chat is on dyeing so it might be of interest to you. Chat starts at 9 P.M. with the main topic usually starting around 9:30. Come join us!
Allen Neighbors
>Cyril, a good sealer is a Lacquer Wash. I use a mixture of approx 65%Lacquer/35%Thinner... I think Carole uses a 50/50 mixture.
I apply a wet coat, and as soon as it begins to dull a little (shows penetration) I turn on the lathe and wipe it off with a piece of clean tee shirt.
If you would let it cure for a few hours or a day, it would probably keep the dye from penetrating through.
