Colored wood
ben d.
>I ran across this web site a while ago and have never done anything with it, but figure someone out there will be impresed as I was. Takes a while to download but the wait is worth it.
http://www.tswoods.com/
ben d.
Colored wood
ben d.
ben d.
I've seen it before, but not in a while
steve antonucci
>It's cool and bizarre all in the same sentence. I wonder how much dye it takes to color a tree and how long?
Steven
Re: I've seen it before, but not in a while
>>...I wonder how much dye it takes to color a tree and how long?
40 years ago we did this with cut flowers and if I remember correctly, it only took minutes. From their sketchy web information, it can't take too long since it only took two years to do "over a thousand experiments" and "successfully color their first 500 aspen trees".
Looking at the log ends in some of their pictures, only the sap wood is colored. (To color the heartwood with this method would likely require adding dye for the entire life of the tree.) If I remember correctly, sap flow very fast in trees, with the velocity on the order of millimeters per second.
Bill Hale / The Wood Spinner
>There used to be a method for fertilizer injection directly into the tree. The device looked like a smokers pipe with a short stem and a large bowl on the end. Drilled a small hole and inserted the stem so the fertilizer could drain out. I would think a system like this would work with undiluted dye not fertilizer.
I don't have a tree I can try it on ! Somebody do it and report to us please.
Good turning and be safe
Bill in CG, AZ.
>I use a hollow rod with a bullet nose and a hose connection to deep water trees and shrubs - push the rod deep into the ground and turn on the water. I'm sure this method would work for injecting dye near the root ends and I'd not be surprised if they didn't use this or something like it, perhaps fed by a backpack sprayer.
The question would be what kind of dye would work and not harm the tree. I have zillions of trees. A tree with a relatively large sapwood might be best.
