THE WOODRAT IS BACK!
Drum Sanding Alternatives
Justin Fields
>Good morning.
I'm looking for some advice on drum sanding alternatives. I am gluing up my first segmented piece. I made a two-sided miter sled set for 12 & 20-sided rings. I cut all my segments and glued them up into half-rings. Next, I'll lightly sand the exposed segment edges on each half-ring and glue pairs up into full rings. No big problems on any of that so far. But once I have my rings glued up, I don't really know how I'm going to smooth them prior to gluing them together.
I don't have any home workshop, nor do I really have space for one. I work in a Woodcraft membership club using their equipment. While they have a lot of stuff, they don't have a drum sander. I don't think I can really keep a hand-held belt sander parallel enough and even enough not to leave waves or other problems that would show up when turning glued-up rings.
So, what suggestions do you all have for cleaning up my segmented rings? What do you all use on finished individual rings prior to gluing them together?
Thanks!
Justin
Re: Drum Sanding Alternatives
Norm Smith
>Justin, You could tape a sheet of sandpaper to a flat table top or whatever and than sand your pieces on that. I often do that for dowls , etc that wharp.
Good luck,
Norm
Stuart Johnson
>Several ways to handle this. One of easiest is to use Cole jaws on your chuck to hold the ring. Flatten one side by taking a light facing cut then sand using a sanding board. To make up a sanding board use the belt (80 grit) for a belt sander glued to a piece of 3/4" plywood cut 4" wide and as long as the belt you will use. I use spray adhesive and after cutting glue it to both sides of the board. Hold the board up and sand at a slow speed watching the end of the board to make sure it isn't rocking. I mark all over the surface with a soft pencil and then sand until all the lines are gone. Check to see if it is flat with a straight edge. My next step is to then stick the chuck with the ring still in place in the tailstock using a chuck adaptor and glue to the prior ring using pressure from the tailstock. Wait an hour and then face off and sand the other side and go to the next ring.
If you don't have Cole jaws you could use two sided tape and stick it to a large faceplate for the initial sanding.
I don't know how this got posted to the wrong thread the first time.
georgetroy
>You can use a safety planner from Woodcraft and put in your drill press. You can also make a flat round disc and use double stick tape you flaten. Another choice I have a Shopsmith with the 12" sanding disc and will flaten a ring free hand by placing in the center. It generates a lot of dust, so I use a large dust collector. to catch particles. I also wear my face mask and dust mask for some operations. Do not try a planer or jointer. I too have Cole jaws I will use to make a perfect round hole in the center of segment rings. A belt sander is also too aggressive for me.
Justin Fields
>Thanks for all the suggestions, folks!
I'll give one or more of them a shot the next time I get into the shop.
Justin
