Neat Trick for Hunter Tools...
Steve Russell
>Hello to the group,
I found a neat way to keep all of the sawdust from getting impacted/stuck/concreted into the screw head hole in the setscrew for Hunter tools... I melt a bit of candle wax into the hole and let it harden. Excess wax gets abraded off, but most of it stays down in the hole, keeping it easily accessible when needed. A quick push or two with the driver and the wax is cleared out and you can easily loosen the screw to move the cutter head. This works so well that I use it on many of my hollowing tools now, so the allen screws stay clean. Take care and best wishes to all of you!
P.S. I sent this into the AAW mag as a tip, maybe it will get published...
Steve Russell
Wednesday Night Turning Chat Moderator
Re: Neat Trick for Hunter Tools...
GaryG in MD
>That sounds like a good idea, Steve. Thanks. I'll give it a try.
I'm curious though -- how does with work with an Allen screw? I would think it would block the hole and be hard to get the wrench head in without melting it out or something. Is pressure enough?
Congrats on your retirement. You're gonna love it.
Cheers, Gary
>Good idea Steve. I haven't had a problem with clogging yet but I use my Hunters mostly for dry wood.
Steve Russell
>Hello Gary,
It depends on the size of the allen screw... On the smaller screws, pressure is sufficient. If the screw is larger, I sometimes warm the wax a little with a heat gun and then push the allen wrench through it. Since you don't really have to screw/unscrew these set screws much, it has not been a problem for me. It's much easier than using a dental pick to unclog the hole for sure. I'm in to easy these days, so I use wax. Take care and best wishes to you and yours!
Steve Russell
Thanks for this tip, Steve
Cyril Griesbach
Dave Noon
>In some indutrial environments, such as steel mills, they use caulking in Allen sockets. The blob of caulk just pulls out and the hole is clean.
Ken Grunke from SW WI
>I have a few hollowing tools where a trick like this is needed. Useful for the jaw screws on a scroll chuck, also. A candle is a good thing to add to a turner's toolbox, I also use it for lubricating drill bits when drilling deep holes on the lathe.
Thanks, Steve.
>I may try that one |;-}
Right now I use a squirt of hi-pressure air to blow out the dust. Wax would be cleaner.
Thanks
