Re: Drain your compressor every day?
Barry Turner
>I bought a Husky 6 HP (yeah, right!) compressor with a 60 gallon tank from Home Depot a couple of years ago. I replaced a 30+ year old Crapsman 2 HP with 30 gallon tank that had developed a bad leak in the tank. It had rusted through the tank on the bottom, probably from not having the moisture drained regularly. Still, it lasted over 30 years.
I promised to be diligent with my new compressor and drain the water from the tank weekly, daily or whatever. I didn't want the new tank to rust through like the old one did. Well, guess what? There's never any water in the tank to drain! Just a tablespoon or so every few months.
I think how often you drain the tank depends on freqency of usage, prevailing humidity in the shop and a little common sense. I use my compressor mostly for blowing wood chips and shavings off my lathe. The compressor cycles once or twice a day.
I don't think there is much benefit to opening that valve in the bottom of the tank if no water comes out. I don't drain the air either when I'm finished either. I do close the valve at the regulator and take the pressure off my air hose, though.
