3-Sided "X" Vase
3-Sided "X" Vase
3-Sided "X" Vase
Brian Hahn in SW Wisconsin
>Elm with acrylic paint, 3" x 6"
A concept piece. The 3 face axes cross the central axis at the "waist" - the faces disappear into the waist and reappear on the opposite side.
Comments and critiques welcome.
Re: 3-Sided "X" Vase
Don Orr
>Great piece Brian. I'm a big fan of mutli axis work and this is beautiful. The trasition at the waist is very nicely done. If I may ask, is the waist turned or carved or both ? I like this a lot !
>The waist was mostly turned with some hand clean-up work. When the piece is spinning on a face axis, the two faces overlap at the waist so there is a small undulating ridge that needs to be removed by hand.
charlie belden
>Barbara Dill's first article on Multi-Axis Turning turned on the AH-HA! lightbulb for me - Arcs Not Full Circles! Adding a twist was another mind stimulating bonus. Visualizing end results for a set of centers is still causing me brain cramps but having samples with centers numbered and some notes sure helps
What got you doing Multi-Axis pieces? Have you done any 3 arc hollow forms?
charlie b
Bob Slocum
>Really nice! For your next one try a slight bend and the waist..?
>Several years ago I saw a picture of a cylindrical 3-sided piece with a 60� twist. Then two years ago I started playing with multiple axes and twists and shapes. It's an interesting learning process and the best way is to just start trying simple things like vases I posted two weeks ago. Then try four or five sides, then change the amount of twist, then...
I haven't tried hollow forms - my interests lie in other directions.
>Hmmmm... Maybe turning green wood and letting it warp... Have to wait a couple of weeks though, the snow is still too deep to be harvesting wood right now.
