Half-size Djembe
Half-size Djembe
Half-size Djembe
Brian Hahn in SW Wisconsin
>Walnut, 7" dia x 12" tall, 1/4" wall thickness. The head skin is rawhide from a deer.
Comments and critiques welcome.
Re: Half-size Djembe
>Good job. I've always wanted to learn to play the drum, and of course would build one. Our former percussion director at the University always hosted a drummer from Guana every summer. It was really great watching them play and of course I drooled over all the drums.
>That's beautiful! Does it make a reasonable sound or is the deerskin too soft? (I read somewhere that for the best sound you have to use goat skin from Africa!)
I'm currently trying to find some inexpensive goat skin to recover a repaired tree inside a saddle that got run over by a tractor. For some reason, my ungrateful goats are disinclined to donate what I need.
don at central illinois
>Those ungrateful goats know the difference between participation and total commitment!
My Drum Making Experience...
Wally Dickerman in Arizona
>Years ago some sort of drum collector showed up in my shop and ordered several of these in different sizes. I spent several days turning them. He picked them up and ordered one more. Then the SOB left town without paying me and I ended up with the final drum. Tht's my once and last experience with drum making.
Wally
I'm with the goats on that one. . .
Bruce McElhaney, Spring Lake, Michigan
>According to a drummer friend, it sounds good.
Deer hide is actually tougher and stronger than goat hide, but being from a wild animal it isn't commercially available in quantity. This hide was from a doe, so it is about the same thickness as a goat hide. It was stretched tight while wet and allowed to dry so it is very tight.
Not a fan of chevron?
Re: My Drum Making Experience...
Mike Jones, Redding, CA
>Bad pic, good drum. A favorite project. It is 14" dia. by 25 inches tall turned from redwood and left 3/4" thick. I made it in two pieces with a healthy mortise and tenon joint. Unusually deep base tones. I have no rhythm, it seems, and after my grandson had his fun with it, I sold it at an art fair for $200.
Also a bit different, the rings that hold and stretch the skin were turned...white oak I think.
Re: Very cool. Always wanted to make one...
>Wow - chain saw as parting tool on the lathe.
I liked the comment he wrote below the video:
"Wet or dry , the outside of these drum shells have to be sealed within 12 hours so as to let moisture escape from internal surfaces , creating compression on external suface when drying . Without this procedure surface cracks up to 5 mm appear within 3 - 4 days ."
Steven Kubien
>The goats do not understand being part of a team.
Steve Kubien
>Looks a lot easier than the way I turned the drums on my Nichols lathe. The drums I turned weren't as big however. The guy who stiffed me on the drums I turned did play a couple for me that he had. Expensive concert. He was an African from Africa.
Wally
adrien Coblentz
>Could I get one of those bits with a 3/8" shaft to fit into my hand drill???
Lan Brady
>This is wonderful. Great job!
Lan
