Sharpening an Elsworth Gouge
Steve in NC
>Hi folks
I just purchased an Elsworth grind bowl gouge. I cannot seems to find the correct combination on my Wolverine to sharpen it. I know you can get a holder specific to this gouge to work on the Wolverine but it seems that with all the adjustments on the Vari-grind there should be a way to make this work. What am I missing?
Thanks
Steve
Re: Sharpening an Elsworth Gouge
>I don't have an Ellsworth gouge but do have an Ellsworth jig. I had to insert a V notch piece of wood in my Wolverine jig. Mine is 1 1/2" tall. To match the Ellsworth jig shape I have the Wolverine set so the backside of the swiveling arm is on the bottom of the 3rd notch from the bottom. The frontside of this arm is over the first notch. Does that make sense. If not I'll take a photo tonight and post it. This should get you close. You may have to shorten the block a little, I'm not sharpening an Ellsworth gouge so there could be some difference.
Steve in NC
>Thanks for the info John. A photo would be helpful. Also, how far out of the jig do you extend the tool.
Re:Doug Thompson has an excellent....
Jamie Donaldson
>...illustration of how to use the Oneway jig and settings on his website at Thompsonlathetools.com
Bill Neddow
>To help in setting up the Wolverine, here is some info that is not clear in the instructions.
Use the adjustment on the Varigrinder (the jig) to adjust to the angle you find on the tip of the Ellsworth tool.
Use the sliding Wolverine bar under the grinder to adjust to the angle on the wing of the tool.
These two are inter-related, so some adjusting will be required to get it just right.
That should give you the exact grind David puts on his tools.
bowlman
>If you want an easy way to exactly duplicate the Ellsworth grind on a 5/8" bowl gouge, contact Don Geiger and purchase the vertical solution. This unit replaces the Oneway sliding arm. It also includes pretty good instructions, a built in gauge to set the 2" projection of the tool, another gauge to set the vertical height to dead center on the grinder axle, and is useable with any size bowl gouge.
I'd also suggest the wheel dressing solution from Don. I have been turning since the late 70's and I have never had a system as simple to use, as precise and as well built as Don's.
I have no affiliation, financial or otherwise, with Don Geiger . Just an extremely satisied customer.
"just a wild and craaaazzzy bowlman!"
robo hippy
>I have the Elsworth jig. I know the end of the gouge is supposed to stick out 2 inches. and they give measurements for where the pivot point is supposed to be. Either of these 2 things can change the exact profile, so you may have to experiment. Close will work, it doesn't have to be an exact match.
robo hippy
Dennis in Southern Oregon
>Bill said it right. You can match any of the jig grinds by adjusting the jig angle adjustment and the position of the pivot rest. It doesn't matter (within reason) how much the gouge projects from the jig. But note that these three adjustments do interact and that you usually have to adjust the jig angle and the pivot position iteratively. To do this easily, take out only half the error at each adjustment.
Note that if too little of the tool projects from the jig you may find that you will be grinding the jig before the gouge reaches the wheel. I have purposely ground down my jig so that I can sharpen gouges that are nearing end of life. Dennis
I only just learned this
Steven Kubien
>I had been fumbling a bit with my varigrind until 2 weeks ago when I was shown how to adjust the leg (for the toe bevel), then the arm/cradle/basket (for the side bevel or wing), then check the leg again and so on. I agree that is doesn't really matter how far the tool projects from the jig, as long as it is always consistent (2" in my case).
Cheers eh!
Steve Kubien
Ajax, Ontario
Texian
>But if you have a home-made jig with a fixed "swivel arm", you can adjust the distance that the tool extends beyond the block, and put a mark on the tool w/ felt-tip marker. At least this works until the tool gets too short.
photos of my set up.
>Here are some shots of the Wolverine jig showing the angle of adjustment on the arm and the block to raise the jig. The height block may not be exact for your ellsworth but is probably close. If I can find the Ellsworth jig instructions I'll post those.
Re: photos of my set up.
Maybe this will help  *LINK*
http://www2.woodcraft.com/PDF/77B61.pdf
Steve in NC
>Thanks John
I think I have what I need to make this work.
charlie belden
>Getting consitent profiles on a grinder using a Wolverine type jig involves
1. the wheel diamter, which gets smaller with use
2. the length of the tool extending out from the jig
3. the angle of the "arm/foot" to the bottom of the tool
4. the horizontal distance from the closest face of the grinding
wheel to the the inside "heel" of the support bar
Here's a technique that will give you consistent results and makes set up pretty quick and easy.
charlie belden
Re: thanks to all
Steve in NC
>This is very helpful thanks.
