Veritas - Innovation in Tools
Turning first plate
Turning first plate
Turning first plate
Craig
>Hello all,
I have turned bed posts and other cylindrical things. I want to turn my first plate/platter. I have questions about how to hold the workpiece while turning it. I have a OneWay chuck, and could get a faceplate if that is what is needed here. I plan to start with a small 1" thick by 7" piece of wood. I cut it round on the bandsaw. Then, how do I mount it on the chuck to turn it? Since it is a plate I don't want any holes in it. That seems to rule out a faceplate screwed to the piece. Do I glue a block on the back that the chuck can grab? If so how do I get the glued on piece off? What type of glue should I use. I have also heard of people using double sided tape. Will that work to hold a workpiece while turning it. If so what type of tape should I use?
Thanks for any help!
Re: Turning first plate
>There are lots of answers to your questions.
If you had Cole Jaws for your shuck you could cut the piece round and grip the rim in the Cole jaws and turn a "Chuck Foot" on the bottom. Cole Jaws are the large plates that allow you to screw gripers like rubber bumpers into them to grip the rim.
The chuck foot could be a tenon Or a "male" part that you could grip with your chuck by compressing the jaws around the tenon. Another approach is to turn a recess into the bottom about an 1/8 or 3/16" deep that you can insert your chuck jaws into and expand them to grip the perimeter of the opening. If you do this you need to leave a substantial rim around the opening. Perhaps 3/4" or more all the way around. If you do either of these, the shape of the rim of the tenon or recess should closely match the shape of your jaws. (Mine are dovetail jaws, so I try for matching angles.) In either case, the jaws grip best if the tenon or recess is just slightly larger than the jaws in the nearly closed position. Use either of those with caution. It may be wise to bring the tailstock up against the center of the work to press it tightly to the chuck in addition to the grip of the jaws. (If you get a catch or make too heavy a cut you can turn a platter into a flying saucer) You can make a cover for your tail center or use a small block of wood between it and the platter to prevent leaving a tail center mark on the piece.
You can glue a block on the back of the piece and grip that in the chuck. Some people glue it on with Cyanoacrylate glue (CA) and when they are finished take a chisel and set it on the glue line and give it a sharp rap and pop it off. You can do the same thing with a piece of brown paper and yellow glue. Glue the block on with a piece of paper with glue on both sides between the pieces and then split the paper later.
In almost any case, you will want to "reverse chuck" the piece and clean up the bottom. There are at least a dozen ways to do this. Again, you could use Cole jaws or you could mount a scrap in your chuck and turn a jamb chuck. That could be a disk with a recess that the rim of you platter would fit snugly into. Bring up the tail stock and clean up and finish the bottom. You could turn away the glue block like this. (Makes me a little nervous to pop them off, afraid I will rip a hole in the bottom.)
And you can use double stick tape, but you need truly excellent tape and you need to clamp the pieces together for ten minutes to half and hour. It sticks better over time. The surfaces need to be very clean and flat and match well. I have done it, but don't trust it for anything heavier than sanding or finishing.
You may end up with a little nib on the bottom that you have to clean up by hand.
Over all, be careful and make gentle light cuts. Many of these methods of mount the work are subject to failing and releasing the piece and you will be working with thin pieces. Sneak up on it and wear your protective gear.
Re: Turning first plate *LINK*
Stuart Johnson
>Jet has a two part youtube video on plate turning that should answer your question.
Jet Platter Turning
Richard Allen
Richard Allen
>There are a lot of ways to mount a small plate for turning. My current method is:
Mount the plate blank between the chuck jaws and live center. The only thing holding the blank in place is the pressure of the live center against the chuck jaws.
Turn the blank round.
Turn a shallow recess in the live center side that the chuck will compress on. The live center side will become the hollow (top) of the plate. So the recess can be 3/8" deep if you like.
Flip the blank around and mount it on the chuck (compression).
There is likely a mark on the (now live center side) blank. Use that mark as your gauge for a shallow recess (1/8" - 3/16" deep) that the chuck will expand into. This will be the bottom of your plate and you should do all the work you intend to do on the bottom that you wish at this point. The chuck will be in the way when you next flip the blank so do enough work out towards the rim that you can complete the plate once you remount the blank. This includes sanding.
Remount the blank onto the chuck expanding. Use the tailstock for support as long as you can while working the top of the plate.
Make sure you work on both the topside and back side of the rim before working on the body of the plate.
1. Mount between chuck and live center (top of plate to tailstock)
2. Mount on chuck (top of plate in chuck)
3. Mount on chuck partial use of live center (top of plate to live center)
Thanks to all
Craig
>Thanks for the responses! They were just what I needed to understand how to turn a platter. The video link was execellent.
Thanks again!
Dick Hines
Dick Hines
>Drill a shallow hole in the center of your blank and use the screw that came with your chuck. You may have to but a spacer between the chuck jaws and the blank so the screw will bot go all the way through.
Another simple way to hold it is clue a block of
henthorn
>wood to your blank with a piece of brown craft paper between. The screw the face plate to the glue block and turn the plate. You can turn the glue block to a small enough size to let you shape the bottom of the bowl and then reverse chuck the plate using a jam chuck to finish off the bottom. Really simple way to to do for me. Of course I turned for 60 years before they developed scroll chucks.
