OT.- Nikon Capture NX
Jorge Castaneda~Downeast Maine
>Hello,D 80 users,
Now that I have the D80 and started using it, I would like your opinion on the Capture NX software:
Is it worth the $130.00 more or less?
I have Adobe Photoshop 6, will Capture NX add functionality or just duplicate it?
Thanks!
Jorge
Re: OT.- Nikon Capture NX
Charlie Anderson
>We have the D80 but don't have the software.
We're just using Photoshop Deluxe 6.0
Richard Allen
Richard Allen
>I have Photoshop 7 and Nikon Capture 4.42 which I use with my D70 (yea I know it's old). I find the work flow with Nikon Capture easier for me to get the results I want. This is especially true when using the Nikon "RAW" format.
For the vast majority of the pictures I take I use Pacasa2 as my photo tool.
When I am taking pictures of my woodturnings I use Nikon Capture as my photo processing tool and Pacasa2 as my catalog tool.
I already owned Photoshop when I was given Nikon Capture, so I didn't have to make the choice about buying Nikon Capture.
>Richard,
I got from your post that Nikon Capture NX is a friendly software, that would be good for me, I had Photoshop a couple years an I am far from mastering it, so maybe is worth getting it.
I'll take a look at Pacasa
Thank you!
Jorge
Re: Spellcheck- it's Picasa.
Jamie Donaldson
keith zimmerman, Normal IL
>IMHO, I wouldn't waste time with Picasa. It will take over your entire system! I downloaded it last year to try out when searching for a photo printing software and I'm still finding picasa files in my photo folders. I feel that Picasa tries to do too much and don't think it excels at anything.
Photoshop is a much better editing tool and has many more controls.
BTW, I found that Photoshop is a better printing software too.
keithz
Mark S. Nadeau
>Hello Jorge,
I'm a professional photographer who has been lurking about on Woodcentral for a few years, entering contests, etc. Your question has brought me out of the woodwork.
I am currently using Adobe Photoshop CS2 and Nikon Capture NX. My operating system is Windows XP Professional SP1a. This will be a lengthy message, but I will keep it simple and try to point you in the right direction. Forgive me if I explain things that you are already aware of.
If you are shooting NEF (Nikon Electronic File) files, which is Nikon's RAW file format, then Capture NX will give you a lot of image control that Photoshop 6 does not offer. But, for starters, please be aware that unlike earlier versions of Capture, Capture NX is EXTREMELY MEMORY HUNGRY. I bought a workstation type laptop in 2002 and still use it today. I originally had 640 MB of RAM installed, but had to upgrade to the allowable maximum of 1GB of RAM to use CS2 and NX smoothly. NX still pegs my CPU when working on images from my D200 (10 megapixels like your D80), but it's bearable. If you have anything less than 1 GB of RAM, I don't recommend it, as it will become frustrating.
Also, with NX, at the end of each use, you will need to go into the Preferences and manually clear the cache. When working on images, NX caches a tremendous amount of data. It does this so that when a previously manipulted NEF is opened, it will open more quickly. If you do not clear that cache at least once in a while, you will suddenly notice that you have gigabytes of space missing from your hard drive! In the Preferences, you can limit the amount of HD space allowable for the cache (1GB should be sufficient), but clearing that cache at the end of each use is a habit you would need to get into. I initially learned this the hard way when I suddenly found myself missing 9GB of HD space after having used NX for about 6 months. I thought I had a serious problem on my hands, but simply clearing the cache freed up the missing 9GB. You never stop learning when it comes to software.
NX has some remarkable functions built in such as the "Color Control Point" feature and the "D-Lighting" feature. These functions are useable on JPEGs, TIFFs, and NEFs, and are demonstrated and explained on the product website:
http://www.capturenx.com/
Also, if using NEF files, camera control functions such as white balance can be corrected in NX if you had the camera set incorrectly when the picture was originally taken.
The whole idea behind RAW files is that they are like a digital negative. No matter what you do to a RAW file, the original file data stays intact. You can always get back to how the image originally looked, no matter how many changes you have made and saved. This is what differentiates the RAW format from other image formats. For a better understanding of the RAW file format I recommend the following PDF file:
http://www.adobe.com/products/photoshop/pdfs/understanding_digitalrawcapture.pdf
Honestly, if you do not shoot NEF files, then NX is not necessary. Photoshop 6 can do anything that NX can do and more (with the exception of the RAW file manipulation). Adobe did not introduce their Camera RAW plug-in for Photoshop until version7, and it did not become a standard component of Photoshop until version CS2 (version 9). So, if you want to manipulate NEF files, you will need NX or an upgraded version of Photoshop and the Camera RAW plug-in. The cheapest solution is most likely NX, just don�t forget about the RAM issue.
The best book on Photoshop is �Photoshop for Photographers� by Martin Evening. The best web resource for photography (traditional, digital, hardware, and software) is
http://www.luminous-landscape.com/
Without knowing more about what your photographic wants and needs are, I don�t know what else to tell you at this time, but I hope that this was helpful. Let me know if you have any other questions.
Sincerely,
Mark Scott Nadeau, Photographer
B.A. B.F.A. M.F.A.
marknadeau@appropriatedlight.com
www.appropriatedlight.com
>Mark,
First, welcome to Woodcentral!
You have certainly answered all the questions in my mind.
I shoot NEF files only when traveling, a few weeks every year, landscapes and people at work and toy with the idea of putting together coffee table kind of books some day.
My operating system is Windows XP Pro SP2 with a large hard disk, but only 512 RAM, I don't know if there is room for more, so for the time being I will stay with Photoshop 6 but will try to upgrade my RAM.
Thank you for the URL's and the Photoshop book heads up and all the info you gave me, I certainly appreciate your time and generosity sharing your knowledge.
Hope that now that you came out, we'll get to see some of your turnings :o)
Jorge
>Thanks for the heads up Keith, after reading Mark's post, I am sticking to Photoshop.
Jorge
Mark S. Nadeau - Portsmouth, RI
>Hi Jorge,
Glad I could be of help. Most likely your computer will accept more than 512MB of RAM. I bought my RAM chip from crucial.com and feel that it is one of the best investments that I have ever made.
As far as my turnings go, just last week I added a woodturning page to my website (www.appropriatedlight.com), so you can see a sampling of them there.
Regards,
Mark
Wow! Fine turnings...
>and photographs.
Mark,
Your site has lots of really good stuff, thanks for sharing it.
My favorite turning is the pitcher.
Thanks again
Jorge
Bob Macgregor
>Lots of nice work, but I agree with Jorge; the pitcher is really a remarkable piece.
