MESQUITE GLOAT
MESQUITE GLOAT
MESQUITE GLOAT
Bill Hale / The Wood Spinner
>I always envy you who live where there are green dumps and lots of trees.
Well today I got mine, $ 80.00 credit in our Flower Shop. The tree trimmer said that he had never taken out a larger Mesquite tree. This was in a residential yard.
Good turning and be safe
Bill in CG, AZ.
Re: MESQUITE GLOAT
Steven Antonucci
Mesquite is a great wood to turn
steve antonucci
>looks like you'll be busy today, huh?
Break out the Anchorseal!
Steve
Re: MESQUITE GLOAT
Re: Mesquite is a great wood to turn
>No the Anchor Seal does not cut it here. I will off load and cut all in 1/2 lengthwise. Then they get piled under a tarp and kept wet with a daily spraying of water. I will immediately start roughing out all of the pieces. I rough the outside of all then the inside of all. Then they go into sealed tubs for curing. I open the tubs daily, blow out the wet air and leave them open for about 1/2 hr. then re close until tomorrow. This takes about three month but almost no cracking.
Hopefully I will get them all rough by the end of the week. Depends on honey dos
Bill in CG, AZ
Re: MESQUITE GLOAT
Ron McKinley
>Bill, is that Velvet Mesquite? I've turned Honey and Screwbean mesquite but I'm told that most mesquite in AZ is Velvet. .....Ron
Re: MESQUITE GLOAT
Re: MESQUITE GLOAT
Ray Carson, Lawrenceville, Nj
>WOW !!! Nice haul. Congrats.
Ray
Re: MESQUITE GLOAT
Re: MESQUITE GLOAT
Brian Hahn in SW Wisconsin
>That's a very nice haul. Hope it doesn't have hardware in it.
Re: MESQUITE GLOAT
Re: MESQUITE GLOAT
George Van
>Nice haul Bill! Have you ever tried boiling after roughing?
Re: MESQUITE GLOAT
worms
robert davis
>mesquite is agreat wood to turn. you can tarn a piece to completion wet. very little crack or distortion problem ..worms will quickly attack the sapwood which is not good for natural edge vessels. when i have been lucky to get a piec or two i put it in aplastic bag and spray with insectide. that works
Re: MESQUITE GLOAT
Re: worms
jim reimers
>about all i turn is mesquite,(live on ranch)and most of it is full of those big white boring worms from some obscure beetle whose name i forget. have found that if i place what i need in a fire ant bed they consume the worms in 24 hrs. or less. before i found this method i thought fire ants had only one purpose, to hurt you!!seeyalaterbye-jimtex.
Re: MESQUITE GLOAT
Fog Tanner
>Bill,
Nice score on the wood. I love turning Mesquite, it finishes out so nice. The Mesqueite you have there must be different than what we have in Texas. When I turn it, I normally will core the piced and then finish turn all the bowls. As long as the tennon is not too wet, then it is good to go. When they come off the lathe they are finished. There is almost no movement and doesn't need the drying like Pecan - another wood I like. For boxes with suction fit lids, I do rough them out and let them dry for a month or so.
Main reason for doing that is the bugs. When there aren't any ants around, they are tough to get rid of. Next batch I get that has worms is going to get gased. I have an old chest freezer that I am going to cut a small hold in, load it with mesquite and hook a hose up to the exhast on the van and let it run for a while.
Re: MESQUITE GLOAT
Re: MESQUITE GLOAT
Bob Macgregor
>Bill,
Have you ever turned any palo verde? If so, what is that wood like?
