PM3520B - Comments Cont.
David - Indianapolis
>Thanks to everyone that took the time to post. As I expected, the comments spanned the range and there was lots of advice on things to try.
I thought I would provide an update as I have done a number of things, followed suggestions, etc.
First, releveled the lathe, to within 0.001 in both x and y.
Second, measured the runout again with a better dial. Impressive, approximately 0.0005 across the speed range.
Third, checked again the alignment of the headstock and tailstock at multiple positions along the bed (as before, consistent along the entire length with the same displacement. As I thought (and Bill Hale suggested) the deviation is consistent along the length of the ways thus it sounds like equipment error not leveling. My thoughts but it can not be shimmed as the deviation is in the horizontal plane and the headstock and tailstock are a tight fit.
Fourth, turned my first box. So I have now made one bowl and one box. Had fun and it didn't seem to matter. The lid fits well. I tried for some decorative detail but kept messing up and had to trim it down. The walls are thin but I think it is pretty cool.
Have included picture of the deviation (same along the entire bed, multiple headstock and tailstock inserts from the new and my old metal lathe tried)
Anyway, going to contact Mr. Osolnik to see if this is an issue and will let you know what happens.
Thanks again,
David
Re: PM3520B - Comments Cont.
Re: PM3520B - Comments Cont - Box.
>Picture of Box
don lewonczyk
>Nice box David even with the off center points. Let me ask this, if you were going to sell that machine how many of the turning pros would buy it from you in that condition? When I get mine if its the same as yours I would first try swapping out the tail stock with a new one or else right off the bat I would ask for both replacements of head and tail stock that were checked for alignment on another lathe. Didn't you say you already had to drill out the holes for the bed extention for it to line up? That would tick me off in the first place. Trust me, you will always have that thing nagging you in the back of your mind. I was going to pick mine up this past Thursday in TN but they are out of stock until sometime next week, when I get it and set it up I'll post the condition of the alignment. I haven't heard from others who bought the 3520B with the same problems as you. Take Care DonL
Bill Hale / The Wood Spinner
>I have to say that I would ask for a replacement. This error would nag on me and I would never be satisfied. Also if you do decide to sell it would you be willing to sell it to a friend? I think not!
If you would not sell it to a friend why keep it for yourself ?
I do realize you are a perfectionist gut that is OK, so am I.
Bill in CG, AZ.
don lewonczyk
>David try going to the tech department of WMH group 1-800-274-6846 ext 1325 and that should get you to Bobby Gannon, he is supose to be the powermatic man and I think he may be able to help you. As Bill Hale said its a machine error, something not milled to tolerance on one piece or the other. WMH will be making the call on the replacements so you might as well go to the horses mouth. Call the people you bought it from just to inform them so your not jumping the chain of command but hey its you money on the line so instead of getting second hand info get it right from the manufacturer. They have been very helpful to me in the past and reasonable. Don't hurt to check it out. DonL
