some sharpening tips
Robin Corell in Atascadero, CA
>I'm not sure which type of chain sharpener you have in mind. There are two types that clamp onto the bar. One uses a small grinder similar to a Dremel with a stone and the other uses a file. The kind with a file is actually more accurate than the one with the stone. But for your purposes accuracy is not that important. I use the type with a file for my milling saw to true up the angles after every three of four free hand sharpening. But for the majority of my sharpening I use a file freehand.
Some of the newer types of chain have a line etched on the top of the tooth. It serves two purposes, first is a reference line for sharpening and second is a safety marker to let you know when the chain is used up. The angles are not overly critical but you do want to use the appropriate size file. And as the teeth get smaller you may need to change sizes of files. This is very important because too large a file will change the angle on the underside of the tooth and if it becomes too obtuse it can become more prone to kick back.
One of the things that will affect the accuracy more than consistent angles is filing or grinding from the wrong side. On a chainsaw you want a burr on the edge and you want it on the outside of each tooth. This means that every other tooth needs to be sharpened from the opposite side. The easiest way to do this is to use a sharpie to mark a tooth and sharpen all the right hand cutters and then turn the saw around and file all the left hand cutters. When using a file I only file in one direction and rotate the file a bit each time. I usually take three or four strokes on each tooth. Rotating the file a little on each stroke helps the file wear evenly and therefore makes counting your strokes more likely to remove the same amount of material from each tooth. On a small bar this is not an issue but it is still best to wear out the file evenly, and keep in mind that chain files are an expendable item. Also do yourself a favor and make or buy a file handle.
You will need to take a bit off the depth rakers every so often. They make a file guide for this and it really is best to pick one up to learn with. it is easy to get carried away or take too much off the rakers and this can really slow down the cutting speed as well as make it more prone to kick backs.
Don't be intimidated to sharpen your own chains, it is not difficult but it does need to be done correctly or it can make a dangerous tool even more dangerous.
Robin
