>Just got this spalted beast mounted. Currently 24+" in diameter, but mounted with the off-center pithe on the lathe axis and have some other defects to work out. Hoping for a 20" sphere. Will be starting at about 80rpm.
Nice branch you got there on that mini-lathe. After you get it down to 20", then even I (or more accurately, my lathe) could handle it... barely (if I had more than 10 minutes to spare; I have to take study breaks or I'd pass out and most likely break the laptop).
>A couple of recent threads have been about using a sharpened pipe to make small spheres. I figure for something the size if that blank, a 16" - 18" diameter pipe should be just about right. Doesn't everyone have a chunk of hardened steel pipe like that just sitting around waiting to be used?
Obviously, I was just kidding.
That chunk is going to take a little work to get it round and even more to hollow it. Good luck with it.
>Since it took the overhead winch to get this thing on the lathe, I suppose I counld rig up an hydrolic holder to mount that pipe . . .
nah, gouges will just have to do.
Hollowing will be an issue because while it is mounted with the pithe on the centerline, hollowing it will be at about a 45* angle. The "roughed" sphere will have to be remounted and wood left at the contact/mounting point that can be removed after the hollowing is done. Yeah, this is going to be interesting all right.
I assume you are turning green and letting it warp. The final shape should be interesting. I hope it works out and you can post the results.
Hint: To get the degree symbol on a PC, hold down the alt key and type 248 on the numeric key pad. The degree symbol appears when you release the alt key. (I did a bit of software in a previous life.)
>I'm probably going to work it to a cylinder with the current mounting, to get the drying "even" in regard to the pithe, then change the fix point to set the hollowing axis angle (thanks for the typing tip), and then complete the sphere.
My largest boring bar for the hollowing rig is 1" and the plan is to hollow the sphere to about 2" thick walls to allow for carving. That's an 18" reach over the rest/gate so I may have to pick up a heavier (1-1/4") bar.
Also have to make a BA set of calipers to check the diameters.
>And I certainly hope it does just that (in fact 3" would be even better) as that's part the idea. I'll also get a bunch of checking, but hope that I can keep them on the small side.
>David Marks told me once he was working on a big redwood sphere and it was a challenge. I see that Jim Barrett on Sawmill Creek posted a photo of the finished sphere, message in the link below. He said it weighed almost 400 lbs before hollowing.
>Yup, that looks to be about the right size |;-}}}} Must remember to ask David how that piece turned out.
I think mere "glasses" will be rather ineffective in this instance; a personal forcefield would be nice though. I put this on an 8" faceplate with 12 #12 screws. With a 150lb blank, I'm taking no chances with a drive center slipping. I'll still feel a lot better when I get it balanced in spindle mode.
>IF the pith is centered, and IF the perimeter of the sphere landed on the same annual ring all around (at its equator), wouldn't the drying process just give you a football shape? Take away either prerequisite and sure you will get odd warping, but if close on both points, do you really expect 3" of movement?
>Sycamore has a radial shrinkage rate of 5% (8.5% tangential). While I will start with the piece round for purposes of hollowing to an even wall thickness, I'm hoping to get as much movement to the oval as possible. There is a sycamore taken down near me that is 50+"in diameter (twice this size) but to use some of it for a piece like I have planned, I'd have trouble in predicting and controlling the grain and the shape change. Here I know the ends will "push out" as the diameter shrinks and that's already incorporated into the design of the final piece. I doubt I'll get more than an 1 to 1-1/2" change (given the 5% radial), but however much I get will be a help.
>Did you remember to use the Numeric Key Pad instead of the numeric keys across the top of the keyboard? Also, did you hold down the Alt key while pressing all three numbers in turn, then release the Alt key? (Some people press and release the Alt key before typing the number keys)
I tried this on three different machines (Win2K, XP, Vista) and it worked the same on each. On a laptop without a numeric keypad I had to hold down Fn+Alt then type 248 on the embedded numeric keypad, then release all three keys.
Note that you can also open the Character Map application (under Accessories) and pick one or more characters, click Select, click Copy, then paste into your application. The � character is about in the middle of row 6 on my machines.
If you have enough screen space to open the browser and Character Map at the same time, you can drag the ČђσГ▲ċ�єҐ to your message composition window. This is the way I often work since I use dual monitors.
Can you cut and paste a photo ? I can't remember what password, user name or whatever I used to use to access Sawmill Creek, so I can't access that link.
Do you mean you can't access the sphere photo? (attached below)
I don't read the Sawmill Creek, but googling for David Marks' sphere turned up that link. Funny thing, when I first went to the site it wouldn't let me in without registering, but after bumbling around a bit it must have changed it's mind and let me access the messages and photos.
