A few amateur questions. I'm the amateur.
Ray Carson - Lawrenceville, NJ
>To the turning crew,
I find the process of pen turning very interesting and have been tempted many times to try my hand at some. It seems as though there is a lot involved with the whole process though. The "mini" lathes, mini tools, pen assembly ram thingy that installs the insert thing. (sorry, I'm weak on the technical terms but I DO understand the process) so...........
1) Okay...anything is possible, right? Is it possible, or should I ask, is it a difficult process to turn pens on a large lathe? Large meaning not a "mini" lathe.
2) Do I need a "mini" lathe?
3) What are some of the basic tools, speciality tools and accesories needed to make and assemble pens? What do I need to try a go at making a FEW pens.
4) Unless your making a lot of pens, is it worth while making just a few pens? Few being 12 or less. You know, just because you like playing football with the guys, it doesn't mean you have the "stuff" to play in the NFL. I don't want to spend tons of money on something that may not be bag. I may find it very frustrating. Maybe I'm thinking of defeat before I actually try, but I would like to test my skills.
By the way, I've looked into my local woodworking groups and there aren't many. I only know of one and it's a VERY basic handy man special type program. How to use a hand saw, how to hold a hammer and drive a nail without smashiing your finger...not that smashing your finger isn't important...but I know how to use a handsaw. That woodworking school wouldn't help me much.
5)Last question....can anyone recommend a book, website, DVD, etc. that might help or give me some insight to my questions.
Any advice is appreciated.
Ray
Re: A few amateur questions. I'm the amateur.
Ron in Drums PA
>Yes you can use a full sized lathe to turn pens.
The only tool you really need to turn a pen is a skew, but a roughing gouge helps too. Full sized tools will work fine.
You can use a clamp as a pen press
You will need a mandrel and bushings
>Ray,
I'm no expert, but I can say this - yes, you can easily turn pens and smaller things on a big lathe. In fact, given the choice and the space, a large lathe makes more sense for general use since you can use it for very small things or large things, while a mini lathe has definite size limitations on the large end of the scale.
For pens, you need a mandrel, bushings for the size of pen kit or kits you use, an end trimmer, a few basic tools (gouges, skew, and/or scrapers), a way to sharpen the tools, some sandpaper, and some finishing supplies. A trip to a local Woodcraft store or a visit online to one of many suppliers will get you everything you need.
I wouldn't buy a lathe and all the accessories just to turn 12 pens then quit. However, the thing about woodturning is many people start with pens and end up getting hooked and want to spend all their waking hours turning - it's a very addictive "sport" and unlike some other activities, extremely quick and easy to get good results right away.
I recommend taking a pen course first. The Woodcraft store here has such courses and after several hours you will leave with a pen and an excellent understanding of what is involved. Based on that, you will be better equipped to make decisions on purchases and whether you even want to continue!
There are lots of good resources. Mr Google can lead you to good web sites. Check the Articles here on Woodcentral. I have several favorite books: for general woodturning, it's hard to beat Turning Wood by Richard Raffan and/or Fundamentals of Woodturning by Mike Darlow. For pen turning, there are several: Turning Pens and Pencils by Christensen and Burningham or Pens from the Wood Lathe by Dick Sing will show you everything you need to get started.
Perhaps someone here knows of a woodturning club in your area.
Re:For a beginner, pens are a worthy .....
Jamie Donaldson
>...and practical project that can become an obsession, assuming you have the temperament for repetative detail work. I would also recommend a spindle gouge rather than a skew for a beginner- skews are scary and have a longer learning curve. You can turn small objects on a big lathe, but not large projects on a mini lathe, and if you find you enjoy turning pens, then larger projects are bound to follow. And we all know where that leads..........
Steven Antonucci
See below
steve antonucci
A: Absolutely.
A: Largely depends on cost and space.
A: you need a pen mandrel and a skew and/or a spindle gouge. Everything else makes it easier. I'd also recommend a pen reamer.
A: With a lathe, the cost of your first pen is high, but goes down after you have the lathe :-) If you wanted to make one pen, I'd say buy one (pen). At twelve, it's a push.
A: Most of the kits have instructions. In general, you need to be able to drill a hole, glue in some tubes and turn a square block to round. Every thing else is attention to detail.
Steven
Cory in MN
>Hello Ray,
I just browsed thru the Amercian Association of Woodturners chapter list and found you are nestled within an hour or so drive of 3 different AAW chapters. Check out the links below, odds are high you'll find someone who is happy to show you the ropes. Good luck!!!
www.atlanticshorewoodturners.com/
www.del-val-turners.com/
www.njwoodturners.com/
Re: A few amateur questions. I'm the amateur. *LINK*
Rick Allen
>If you just want to turn a few pens then find someone local (there have to be loads of folks in your area) to help you with that goal. No lathe, no tools. If you decide you like turning pens then you will know how one person does it and what tools they use.
Bucks Woodturners meet 3rd Monday each month 20 minutes away. I am sure you could find someone in that club who would be happy to help you make a dozen pens.
Bucks Woodturners
Nah...
Ron in Drums PA
>I was taught to use a skew the first week that I was turning.
No one told me to be afraid of them, so I wasn't.
HeatherA in Alaska
>For resources Penn State has a free penturning dvd that I found usefull. Hey, it's free! It's towards the bottom of the page. Keep in mind that they want to sell stuff. Not every gadget is necessary. When I started turing pens I called Bill at Arizona Silhouette and he told me what I really needed.
Heather A.
Pennstate industries
Re: Nah...
>I agree and Nick Cook is now teaching the skew as one of the first tools. He said it was easier for students to understand how the bevel works. Now I wouldn't teach them bead turning with the skew as the first thing but then you don't really do beads on pens all that often.
Bill Hale / The Wood Spinner
>Ray-- Welcome
Like Rick Allen said check out Bucks first. Get a little hands on before you buy anything. Don't get hooked on buying a big set of tools as you may never use some of them.
I check AAW resources and there are no members listed in Lawrence ville.
You will find that almost all wood turners are willing to help get you hooked, oops I mean started.
Good turning and be safe
Bill in CG, AZ.
Re: Nah...
When I started turning, everyone I talked to told me to run, run away from the evil skew. But the books I had (Darlow, Raffan, Rowley) all said the skew was great! I decided if they could do it, I could too. Following the instructions in the books, I was a "master" in a very short time. Well, never a master, but the skew IS now my favorite tool at the lathe for spindle turning. Thinking back now, the people who told me to hide from the skew were primarily bowl turners.
I'm with you Ron
Steven Kubien
>I didn't know I was supposed to be scared of the skew so, green as can be, I jumped right into using it. Perhaps I was lucky in that I knew how a bench chisel and plane iron work and the skew is really no different (at least to my way of thinking).
Steve Kubien
Steven Antonucci
Ever try to use a skew on the inside of a bowl!
steve antonucci
>I'm actually attempting to skew finish the outside of vessels and bowls to cut down on sanding. Still a work in progress...
Steven
Mikeb
>Checkout the Penn State Industries website @ www.penstateind.com and they have a whole host of ideas and even a pen turning video(selling the product). I have student in grades 6-8 turning pens on mini and full sized lathes. It is fun and rewarding and gets many compliments.
Enjoy Mike B.
I have...
keith zimmerman, Normal IL
>Not knowing what I was doing, I hollowed my first bowl with a skew. It was also the first time I ever touched a lathe. I discovered at the first club show-n-tell I attended that hollowing with a skew was not common practice. You should have seen the winces by members in the audience. I probably couldn't do it now if my life depended on it.
keithz
Lynn Edwards
>David Hout did a video on DIY network on turning pens. There is a very basic how to at;
http://www.diynetwork.com/diy/wt_tools_techniques/article/0,2025,DIY_14436_3307875,00.html
Hope this helps
DIY Network article
Darrell Feltmate
>Quite simply, you can turn small stuff, i.e. pens, on a large lathe but you can not turn big stuff on a small lathe. For pens I like a lathe that turns at least 2500 rpm but slower is fine at first. Once you have a lathe and basic tools, for pens you need a mandrel (about $20); trimmer (about $15); pen blanks ( about $1 each) and pen kits (about $2.00 each and up). So 12 pens cost about $70 or $80 depending on what you buy to start. This assumes you already have a lathe, tools and a drill press. You can drill the blanks with a hand drill, but buy extras if you do so. Unless you are really good with that hand drill get ready to say "oops." It works out to $6 or $7 a pen. Not bad.
If I may blow my own horn and note that I do not as yet have a pen turning page up yet, take a look at my web site. It can be a help for starters. O, make the sharpening jig. Trust me on this one.
Around the Woods
eaglesc
>Yours is a loaded question.
The use of mandrels, ready made bushings,pens are a convenience and not really necessary.
It depends on how much you want to "do yourself"
The thing about all the "must haves" is they make it possible to successfully make a pen if you are just starting out with both lathe use and pens.
If you wanted to forego the"compulsory" start with a slim line then you could turn different styles without a mandrel.Use just a dead center and live center and turn 1/2 at a time.
You could turn slimlines with a bolt from the hardware store as a mandrel in conjunction with a Jacobs chuck.
You can also make your own pin chucks.
Many use a disc sander and a jig to "square the ends" to the tube making a pen mill unnecessary.
Everything I have mentioned above are things I have tried in experimenting with this craft.
I did not take any courses and I believe they are pretty much a waste of money.
When going to woodworking stores that cater to penturners I see boxes of corset waisted slimlines laying around on the counters turned by customers. A course many times won't even instruct yoiu how to "prep" a blank.YOu show up and everything is cut, drilled, tubed,glued and milled.
Those are the foundations of constructing a pen, all you are required to do is turn to the wasp waist and say "look what I did!"
The best site for someone wanting to learn how to make a pen is one that Russ Fairfield set up.
So in answer to your question you need as much or as little as you want balancing how much time and effort and inginuity you wish to apply.
Making a pen Russ Fairfield
Another Good Article *LINK*
Ron in Drums PA
>By our own Jim Shaver
Building On The Basics
Response to John
>I have the book "Turning Wood by Richard Raffan." It's a great book. Thanks for your advice.
Re: AAW members from Cory - THANKS !!!
>Cory,
I did a bunch of search engine searches and couldn't find squat. Thank you very much.
Ray
Re: Response from Darrell
>Very helpful !!
I was hoping someone could give me the "lowdown" on the basics.
Thank you,
Ray
Re: Response to Russ
>"So in answer to your question you need as much or as little as you want balancing how much time and effort and inginuity you wish to apply."
Nicely put. :-) Thank you Russ.
You responded to my questions by saying they were "loaded." I didn't state a few facts (tools I have, my budget) and my post was kind of broad in nature. I didn't want to take a lot of room up on the messageboard.
I did however get exactly what I was looking for. Advice from a multitude of memebers at WC. They are the best advice givers. :-)
This is something I am willing to attack with a great deal of enthusiam and willingness to accept screw ups. I mean if you screw up a pen, your not wasting a huge amount of wood.
Thank you for your candor. It's appreciated.
Ray
Thank you fellow woodworkers :-)
>To all who posted,
I didn't have time yesterday to look at the thread as it was in progress as I got very buried in stuff at work. That is what I'm here for. :-) (I think) :-)
Seriuosly, I realize that my post was very broad in nature and I could have given more information on my skills, budget, equipment I already have, etc.
Letting the "WC group" respond to my post before I had a chance to respond was very helpful though and I appreciate everything everyone had to add and suggest.
I made a copy of the entire thread so I have all the LINKS, websites, etc.
I do have a lathe and the basic lathe tools. Skew, Gouges, parting tool, etc. I would need a mandrel and the pen parts but it looks as though I can give it a go with what I already have.
I enjoy a challenge and making things, so just buying pens is really not an option. Also, I'm a tool junkie by nature. I can't help myself. :-)
Seriuosly, it sounds as if I can do this. I've been making shavings since I purchased my lathe about 2 years ago, bought a used Tormek to make sharpening a little easier, trying different lathe skills using the books and web findings I have and found.
Anything I've turned to date has been little finials, miniature baseball bats, spindles for.....nothing. Just small stuff using scrap wood, trying to get the feel back from my days turning in high school.
I do not have anybody to turn a wood bowl or vessel for so I wanted a project if you will to "show off" my skills a little.
To wrap it up, everyone here at WC is....as always....very helpful and HONEST in thier advice. I will take your advice and wisdom and see what happens with pen turning.
Thank you,
Ray
