Couple questions on Jet mini-lathe...
Rich Glisson
>As a newbie with a new lathe, I've been wondering about a couple of things. Why does Jet put the access door to the belt and pulleys on the BACK side of the machine so that you have to be a contortionist to look in? Is there some fundamental rule of lathe design that is escaping me?
Also, the drive center that came with my lathe (a JWL1220) has flutes that are square/flat on the ends so that they won't cut into the wood unless you beat the heck out of it. Shouldn't they be sharp?
Thanks!
Re: Couple questions on Jet mini-lathe...
Brian Hahn in SW Wisconsin
>My conclusion about the "conveniently" placed door is they didn't want to spoil the sleek and stylish look of the front of the headstock. It is a royal pain!
The spurs of the drive center should be sharp. I file mine when they get damaged or dull. I hate drive centers with very blunt spurs that need major reworking to get them sharp.
Rick Allen
>Congratulations on the new lathe. You are going to love that lathe.
When the Jet mini was originally made it was a knock off of the Vicmarc mini. The Vicmark mini had an open back for the belt access.
You usually want to have good access on the front side of the lathe when working near the headstock. Opening up the front would make the front side of the headstock weaker. To overcome that weakness the casting needs to be deeper. That deeper casting would get in the way. So putting the deeper casting on the backside gives the strength needed while still providing access to the belts.
I have sharpened the spurs of a drive center on my grinder. This is a quick and effective solution to a dull spur drive. I also like to grind a nick in the side of one spur, near the base of the spur, so I can remount work on the same spurs (without the nick all the spurs look the same to me). Put a mark on the workpiece indicating where the nicked spur was located. Then when remounting between centers the workpiece is more likely to run true.
Dick Hines
Dick Hines
>Some questions are just better unasked. You just take thing as they come.
>I mark my spurs with a dab of bright paint on the outer edge of one spur.
After a couple of sharpenings my spurs aren't symmetrical and being able to remount a piece is the same orientation becomes more important.
Dick Coers
>Speaking of the dull drive spur, I might mention that I never muscle in the drive when it is in the headstock. I don't want to abuse the bearings by overtightenig with the tail stock, or by hammering on the stock and making the bearings take the hit. I knock out the drive spur and tap it in the turning stock with a wood mallet. Most drives have a reduced diameter on the end so if you abuse it with a metal hammer it will not mushroom and spoil the fit on the taper.
Allen Neighbors
>Rick, thanks for the good explanation! What you said makes a lot of sense.
I have a Vicmarc VL100 Bench Model. It does have the open back on the headstock, as you said, but there is a horizontal slot across the front of the headstock that's about 3/16" wide that you can peek through while aligning the belt. As long as there is light falling on the background, you can see okay, but if it's dark in the background you can't see anything.
My motor is mounted at the back of the lathe, a little higher than the bed (Motor weight is the tensioner for the belt), so it's imperative that the opening be at the back. This may be why they had the opening there, to keep from making two different styles of headstock casings.
The drive center I use on my 1640 is one of those you mount in your chuck. I ground the center deeper around the point with my Dremel, to make the ears a little longer, and I blunted the sides of the ears, so it wouldn't be as apt to cut a circle in the end of the piece. I also take it out of the chuck and tap it in with a mallet to mark the wood, so I don't put undue pressure on the headstock bearings.
Re: It's very easy on both you and.....
Jamie Donaldson
>....your bearings to mark the drive center point on the blank, and then have a few whacks with a large chisel in the X figure. You can then mount the blank on the lathe with the chisel cuts aligned with the drive spur, and snug tight without undue stress on the drive spindle and bearings.
Put a mirror on the door.
>someone else suggested that. I haven't tried it yet but it should allow you to see the belt making it easier to change.
I also sharpen the spur drives. I simply put a 45 degree bevel on the end. Needing to replace the spur drive in the exact location must be a common thing because I also use a dremel to cut into one tooth. this leaves a mark that I can find so that it can be replaced in the exact location.
Yeah...
Rich Glisson
>...because my drive spur has the fat truncated flutes I actually cut 2 kerfs in an 'X' shape in the end of the wood with a handsaw.
Hmmmm...
Rich Glisson
>As far as I can tell the headstock casting is symmetrical aside from the access hole in the back. There is so little stress on that puny lathe that I don't think I buy the 'weakening the casting' explanation. Surely it must have occurred to every one of the hordes of people that have used Jet mini-lathes that it would be much less user hostile to locate the door on the front. I guess it will remain a mysterious annoyance.
Re: Hmmmm...
>I forget which lathe but it might have been the early Rikon mini's, the whole end opened up to make changing the belts a breeze. My Nova Comet has a door that opens on the front. So I don't buy the lathe stability thing either. In fact I wrote the Nova people and asked them if I could cut a hole in the bottom of the lathe to mount the motor below the lathe.(this was pre jet mini era) They said it wouldn't hurt the lathe at all. I've been running it that way for close to 10 years.
eaglesc
>I have two Rikons and a JET.
By far the Riknos are easier to change the speeds, but onb the JET I just count the Steps with my finger.
I never look at it and change speeds in less than 15 seconds.
Wilford Bickel
>One of the main reasons I chose the Delta Midi as my portable demo lathe is because it has a front door to change the belts. After fighting the club owned Jets in teaching training sessions I would not buy the Jet mini due to the aggravation of the back access door. Appears it is just Jet's design as Delta and others run a front door with no problems.
eliot d
>I'm not crazy about the rear door, either; but what I really hate is the fact that it's practically impossible to see in there to move the belt even if you shine a light down into where the rear door opens. Instead what I have found is that you must position a light source much lower near the door that opens on the left side of the headstock. Then it's easy to see what you're doing. Otherwise , it's a great little lathe!
