First bowl
First bowl
First bowl
Toney Robertson
>After watching Bill G's DVD a few times I finally took the plunge and did my first bowl.
Spalted maple, several coats of Danish Oil and then Beall buffed. 8" in diameter and 4" deep.
That transition at the side/bottom is a pain.
Thanks Bill for the great DVD.
Comments welcomed.
Re: First bowl
Pic #2
Toney Robertson
Re: First bowl
Pic #3
Toney Robertson
Re: First bowl
Steven Antonucci
Is that a center mark in the bottom?
steve antonucci
>First, let me congratulate you if this is your first bowl. It looks great. Way better than my first 100 or so...
On the bottom, I thought a saw a center mark? If that's what that is, then I would sign over it to disguise it. I've been using a brand that I heat with a torch, and those things disappear.
Disregard if it's a spalt spot, but you should still sign and date it.
Steven
Re: First bowl
Re: First bowl
Lan Brady
>Toney,
I think this is an amazing first bowl.
Lan
Re: First bowl
Re: Is that a center mark in the bottom?
Toney Robertson
>You are correct sir. It is a small piece of center mark left over.
What kind of brand do you use? Just your initials or do you have a logo? I do have a brand that is just my initials in block letters. This bowl is not terrible thin but do you have to worry about the heat from the brand if the bowl is very thin?
If you sign it what do you use - a sharpie? Will it be permanent over the wax?
Thanks for the comments.
Toney
Re: First bowl
Steven Kubien
>Hey Toney,
I cannot speak for brands but as far as signing your work, go to your office supply store and get a Staedler pen with archival ink (I think architects use these but don't quote me on that). The ink doesn't fade and will last forever. Sign your piece before you apply any finish and let it dry (10 seconds, 30 seconds, 1 minute, whatever). I have applied danish oil, walnut oil, shellac over the ink with no degradation.
Hope this helps,
Steve Kubien
Re: First bowl
Looks great Toney!
Dave Peebles Lyons, Ohio!
Re: First bowl
Re: First bowl
Bill MacLachlan
>An excellent first bowl.
Re: First bowl
Re: First bowl
Mick
>WOW, First bowl & a master already..you got talent..
Re: First bowl
Steven Antonucci
I brand with a Wire...
steve antonucci
>I have a symbol (a set of symbols, actually) that I have made out of bent wires. I have also carved a symbol in a brass block. I know you can also buy commercial brands.
I wne tot the craft store and bought jewelry making pins. You can also use armature wire. Just don't use aluminum (doesn't transfer heat) or copper (melts). I hold it with locking pliers and heat in a torch until it starts to glow, and then press into the wood. If you do it carefully, you get one clean impression that will cover the mark. You can then sign it with a pen or engraving tool.
Steven
Re: First bowl
Re: First bowl
Toney Robertson
>Thanks to all.
Mick, your master comment made me laugh.
I am HARDLY a master. Just someone that is trying to muddle through.
Bill G.'s DVD was a god send.
Thanks,
Toney
Re: First bowl
Allen Neighbors
>Tony, that's a truly nice bowl... especially for a first!!
I sign my pieces with a cheap woodburner with a sharp-point tip. It's a lot slower than the high priced woodburners, but it works for me... Date, Type wood, Brand.
I sign it before I put the finish on the bottom, no matter how thin.
Re: First bowl
Photobucket is timing out
Carole Valentine
>At least for me on DSL. I'll try again later.
Re: First bowl
Hellofaguy......
>He posts a picture of his first bowl that looks better that the first twenty I made and you point out that is has a pin prick left in the bottom. Nice guy. Hellofaguy. I'm just giving you grief. It was all I could do to resist. Good idea to cover it with the brand.
Good looking bowl. If the bottom is thick enough, you may be Abel to reverse chuck it and make the bottom concave enough to cut the center mark away.
Re: First bowl
Re: Hellofaguy......
Toney Robertson
>I PROBABLY would have enough wood to make the bottom more concave and take out the mark but .... I don't think I am that brave yet.
I am pretty happy with how it turned out and I would hate to make a funnel out of it just for a little mark.
I think the brand idea is a winner.
Thanks,
Toney
Re: First bowl
Toney Robertson
>I don't know if I could use a hand held burner. Not with my hand writing skills. No one could read it.
Maybe that would make it worth more! VBG
Toney
Re: First bowl
Carole Valentine
>Toney, that is a fabulous first bowl. There is just a hit of ogee at the rim, which is nice. As for the tailstock mark, if it is not too deep, you should be able to get that out with a small sanding disk chucked in your drill, a dremel or with a chisel and some hand sanding. Nice work. :)
Re: First bowl
>You should be proud of that bowl. It's very nice, period. Not for a first bowl, it's a nice bowl.
Welcome to the slippery slope. Now you "NEED" a bunch of more stuff. Like a depth gauge. And calipers. You can buy them or make them. It's part of the fun of this obsession.
I have a home made caliper that looks like a giant pair of scissors with the blades bent into a circle. It works like the double ended figure eight calipers, except you can hold it in your hand like a pair of scissors. With them you could just measure the bottom thickness.
Or, you can set your bowl bottom up on a flat surface and rest a ruler or straight stick across it and measure how tall it is. Then measure the depth of the bowl with the straight edge across it. Subtract one from eh other and you get the bottom thickness.
You already KNOW that the hole left by the center did not come through to the inside. (???) So, you know there is still SOME solid wood left. My experience is that the bottom can be substantially thinner than the walls and still be a very successful bowl.
So, you could do as Carole suggests and just sand it out. I have finished the bottoms of many bowls by chucking a small sanding pad in my Drill Press and by either setting the bowl on he table and bringing the pad down to it or by just holding the bowl at an angle, sand a very nice depression into the bottom.
If your tail center permits it, you might remove the pin. I have used one with just a cup of years. I like it better because it permits moving the piece in smaller increments. That darn pin wants to go back into the same hole every time. I have plastic and wooden covers for my tail center that allow me to use it as a pusher that does not leave a mark.
Re: First bowl
Re: Toney- that is an awesome first.....
Jamie Donaldson
>..bowl, and don't let any of these guys talk you into going back and make modifications to it! Let it be! Make improvements in the NEXT bowls you turn, because going backwards never works well. Keep it as an example, because it's better than many produce after making 50 bowls!
Re: First bowl
Toney Robertson
>Nope, I am not going to touch it. I could just see putting it back on the lathe and then getting a major catch or turning it into a funnel. Too much risk, not enough reward.
I think I will try to "brand it" away. That should cover up the mark like Steve said.
Thanks for the kind comments.
Toney
Re: First bowl
Steven Antonucci
There's one in every crowd :-)
steve antonucci
>Wherever I go, I'm him.
I figured that the brand carefully applied would make an almost perfect bowl perfect. Years from now, when Toney picks it up, he won't be nagged by that little center mark cause it will have been carefully disguised by the brand.
My early bowls have all been disguised by much more fire than the brand...
Steve
P.S. Toney make sure you "test brand" a scrap first so you know how much heat you need to make the brand. Too little is too light, too much will set the bottom on fire. DAMHIKT
Re: First bowl
eliot d
>It's a wonderful first bowl -- and for that matter, the nth bowl! In the future , though, it's best to remove all signs of how you chucked it, or whatever. And that really does mean getting rid of those little center marks, nubs, etc.. Just leave a little more wood at the bottom before you reverse chuck it. It's these little things that make a difference. Art Liestman, a fine mathematician and superb turner, once impressed me with the comment, "Good enough is not good enough." You will find that a small , cheap carvers chisel that's really sharp, and that is curved a bit like a spoon, will come in very handy for cutting away those little nubs that are often left over at the bottom.
