REAL MILK PAINT
First lathe, first project!
Rich Glisson
>Hi everybody--
I have been hanging around WoodCentral since the dawn of time, mostly lurking around the hand tool forum. I got a Jet JWL-1220 mini lathe for my birthday earlier this month and have since been avidly reading the turning forum posts. I saw the marking knives Dominic Greco posted here on 2/11 and that inspired me to make a couple for my first turning project...thanks for the inspiration, Dominic!
I used cocobolo and made the ferrules out of brass tubing fittings. The blade for the small knife was made from a worn-out Bosch jigsaw blade, and the blade for the larger one was made from a defunct 6" jointer blade. The blades were shaped free-hand using my stationary belt sander, a grinding wheel, and a Dremel with various grinding stones, then polished with 600-1500 wet/dry sandpaper and Mother's mag polish. The little brass pieces ("sub-ferrules"?) projecting from the ferrules were made from 1/4" brass rod (I inserted the brass stock in a hole drilled in the end of a block of wood and ran the block through a bandsaw to split the brass in half lengthwise). The blades are jammed tight in 1/4" holes bored in the knife handles, and epoxied with JB Weld. The cocobolo polished up beautifully on the lathe, but I added a very thin coat of tung oil varnish for good measure, followed by wax.
I made the smaller knife first, and after trying it out realized that it is important to keep the blade short on this kind of marking knife so it can be grasped like a pencil. As a result I made the ferrule and blade shorter on the bigger knife. I don't think it is so critical for the small knife, as it can be held almost like an artist's paintbrush when marking dovetails, etc. Also, I realize that a round profile on a marking knife is not a great idea, but can't bring myself to grind flats on them. Maybe after they hit the floor a few times!
I had never done any turning before, and enjoyed the challenge of figuring out how to mount the turning stock for each step. I got a Barracuda chuck and a Jacobs chuck with the lathe and used both, along with a mandrel I made from a 1/4" carriage bolt shank. I screwed the mandrel into the blade end of the handle and drove it with the drill chuck to finish the other end of the handle.
All in all, a satisfying project. Thanks for your interest!
Re: First lathe, first project!
Another pic
Rich Glisson
What great work!
Robert W
>Nicely done. I think you will get a great deal of use out of them, and I like the custom design a lot.
Robert
Ric Taylor
Ric Taylor
>Nicely done! You're off to a terrific start.
Ric
Dennis Yoder
>Rich, very nice form and polishing. Welcome to the wonderful world of turning. Dennis Y
Brian Hahn in SW Wisconsin
>Very nice and useful. They look a lot better than my first attempts!
I'm envious, dude...
Eddie Pacheco; San Jose, Ca.
>My first piece of lathe work looked like pedigreed firewood.
Dick Hines
Re: Another pic
Dick Hines
>If this is your first turning projects I can't wait to see what you do in a year or so.
Keep posting.
Carole Valentine
>Beautiful knives, Rich! I feel the same as Dick - if this is your first turning effort, I want to see what you make in a year!
Molly Winton
>Beautifully crafted Rich. You've got reason to be very pleased with yourself. It's obvious you take great care with the quality of your work. I also look forward to seeing more of what you produce.
Ron McKinley
>Good on ya! If you keep that up you will surpass most of us in 6 months. Keep on turning!
Remember: A turning a day keeps the doctor away........Ron
Wow Rich!!
Dominic Greco in Richboro PA
>Rich,
Your first project, you say? First project,....really? As in, "I've never turned anything before in my life", first project? Then, you've got some natural talent them my friend!
You did an excellent job. Not only on the turning, but on the blades and the ferrules as well.
See ya around,
Dominic
Allen Neighbors
>Rich, you've learned a lot since 'the dawn of time', my friend. These are amazing, and truly well-crafted. I'm like the others... just anxiously awaiting the next pics of your turnings.
Welcome to the vortex!!
Steven Antonucci
Way better than MY first project...
steve antonucci
ebd
Beautiful
ebd
You don't need no stinking year......
>to hone your talents. These look great. I want to see what you do NEXT!
You have set the bar pretty high. There will be troubles ahead. The fun begins.
Re: Wow Rich!!
Rich Glisson
>Hi Dominic! No, I've never even watched anybody turn wood. I did buy a Richard Raffin video a while back, though. Hmmm, maybe I should have mentioned the half-dozen catches that happened while making each knife handle!
Thanks, everybody!
Rich Glisson
Bob Macgregor
>It looks like you have been reading the posts on photography, too!
Nice knives, nice pics!
Re: Thanks, everybody!
Pete Kopp
>Hi Rich- great job as usual. I've never posted here before, but felt I had to now. I grew up with Rich and believe me when I say that he never does anything that isn't just about perfect. Rich can do this quality of work on houses, cars, motorcycles, you name it. Guess you forgot to tell me about your new lathe. Enjoy and don't drive youself to nuts trying to outdo this!
charlie belden
>Nice tool making - the knives metal work is terrific- the wood selection, turning and finishing are of the same quality. The integrating is what's often overlooked - but not by you. Attention to detail is so nice to see.
Look foreward to what you come up with next.
charlie belden
