Sliding Tailstock
Sliding Tailstock
Sliding Tailstock
Bill Gasper
>I wonder if anyone else has experienced this and if so do you have a solution? On my Oneway 1640 when roughing out a bowl I use a 4-prong drive and run the tailstock up tight. As I proceed, I occasionally give the tailstock a turn to keep tension on the blank and prevent slipage. Even though I have the locking lever clamped tight (very tight) I can make the whole assemble slip by turning the adjustment wheel. I don't want to force the locking lever any tighter for fear of causing damage. As it is, I lock it so tight that it is very difficult to release and unlock the tailstock. Any help would be appreciated. Thanks!
Re: Sliding Tailstock
Barbara Gill, Remlik VA
>Bill, I do not have this problem with my 1640. I would suggest you either call Kevin at Oneway or possibly go to the Oneway forum and ask the question.
Don Orr
>Oneway machines their beds/ways very smooth. There are some proponents of roughing them up a little(no, not smacking them around in a dark alley) with a Scotch Brite type pad or fine sandpaper. Some even say you should let them rust a bit so the tailstock can bite better.
>I used coarse sandpaper to rough up the ways on my Jet 1642. It stays put now, even when oiled.
Steven Antonucci
Check under the tailstock
steve antonucci
>If there is any sawdust or other crud, I sometimes have the same issue with my Nova. Blowing it off with the compressor and making sure the ways are clean almost always fixes it.
Steve
P.S. I let my ways "rust" a bit to get a better bite, too.
robo hippy
>I had some one at PM explain it to me this way. If the tailstock locked down totally tight, and you apply too much pressure, you can damage the headstock and/or the tailstock, as in break them. There should be a little give to prevent you from doing this.
robo hippy
Rick Allen
>Sounds like you may want to clean the underside of the tailstock, the clamping block and the ways. While you are at it clean the underside of the banjo and the clamping block for the banjo. I clean these parts a few times a year. More often if I am turning green wood.
I would suggest a solvent for cleaning such as lacquer thinner and a cloth. If you come across something difficult to clean off then try a plastic scraper. These components are cast with mild steel and you can easily scratch or dent the surfaces so avoid using steel scrapers.
Once everything is clean put on a thin coat of your favorite rust preventative. I have used various waxes and Boneshield. A friend of mine is partial to "pledge" wipes. You want to protect the steel surfaces without a build up.
Bill. I do the same as you...
Allen Neighbors
>using the 4-prong drive, until I get the chuck tenon made, anyway. I also had to give the tailstock wheel a little turn to keep tension on the prongs, and have had the same problem of tailstock slip. After cleaning the ways and the bottom of the tailstock, it still does it. But I think that's the way it's made. If you didn't have any slippage under pressure, you could be placing too much pressure on the headstock bearings.
In order to keep the 4-prong drive from slipping, I used my dremel tool and an HD cuttoff wheel to lengthen the prongs a little bit (by grinding away metal between them), and also took off some of the sharpness along the edges of the prongs. (They were so sharp that when trying to spin the blank, they would just slice through, making a circle for them to spin in.) My prongs are now about 1/4" long, and blunt sided.
I use a 1" forstner bit to make about a 1/8" deep hole to insert the 4-prong drive into. I then use a mallet to give the drive a rap to make the indents for the prongs. Then I mount the 4-prong drive in the chuck, and mount the blank. It's easy to align the prongs with their indents, and then bring up the tailstock to press it home.
It works, and I rarely get the slippage of the drive, and don't have to put so much pressure on the tailstock to keep it spinning. HTH
Something isn't right...
Peter Teubel
>On both my 1224 and 2436, I almost think the tailstock quill threads will strip before the tailstock creeps. I never have to reef hard on the locking handles to secure them. If cleaning the ways (both under and on top) doesn't help, call Oneway.
Dave Peebles Lyons, Ohio!
>Hi Bill,
What Peter said... I have never had my tailstock move on my 2436. It is one of my favorite things about the lathe. I would also clean everything up and try again. If all else fails give Kevin a call.
But I would never ever rough up the bed to make it lock down. It should not be needed on the Oneway.
Dave
Bill Gasper
>Thanks for your help and all the suggestions! I will clean, adjust and see what happens. BTW, I wouldn't consider roughing up the bed either. Here's a suggestion from Kevin Clay at Oneway:
"First thing I would do is to ditch the spur for driving a bowl. You have to put a tremendous amount of pressure on a spur to get a good amount of driving force. Get the faceplate that came with the lathe and get two 1/4 inch bolts about an inch long. Sharpen a chisel point onto the bolts with a grinder. Put the bolts into the faceplate from the back, 180 degrees from each other and then put some nuts onto them to hold them in place. You now have a 6 inch two prong spur. You will be able to drive large blanks with minimal pressure. Your live center will last a lot longer and you will no longer have problems with tailstock creep because you just don't need that enormous pressure to drive the work.
As for the tailstock creeping I am unsure if you have is unusual. If you put enough pressure on something it will move. Our screw in the tailstock is an acme thread so it is very effecient at pushing so you can develop a lot of force."
Allen Neighbors
>I don't rough up the bed on mine. I just clean it, and use a little 400 grit wet or dry on a flat board to keep the dings down (I'm a klutz, what can I say?). I don't have any trouble with it creeping now that I quit using the tailstock to sink the drive center. I love everything about my 1640.
Another Spur Idea...
Peter Teubel
>When I mount a bowl blank on the lathe between centers, I use a 2-prong spur drive. I drive it into the wood at least 3/4" with a mallet before mounting on the lathe. I use this technique for *ANY* size blank and have never had it slip....ever. And it doesn't require a ton of tailstock pressure.
