a couple of Black Walnut bowls
Brian Simmons, Heflin, AL
>Here for your viewing pleasure are 2 black walnut bowls. The smaller on I turning in late 2006 and the larger one I just completed. The process is to mount using hot glue, turn the bottom and then remount using hot glue again and hollow. I went through around 12 'blanks' before I was able to turn the first one intact. The second was the only survivor of 7 blanks. For such a hard nut to crack, they are not as thick as they should be ;>
