Picture Size.
Picture Size.
Dick Hines
Picture Size.
Dick Hines
>I have been trying to post a picture of the big burl I collected last Sat. I get the message that the picture is to big.
I have resizes the picture. W6.00 , H 4.50 Resolution is 600 pixles. The 6X4.50 worked before but I did not have the option for resolution settings.
Re: Picture Size.
Re: Picture Size.
Allen Neighbors
>My picture resizer makes them 600 x 480 pixels.
In event it doesn't work, I open them with Microsoft Photo Editor, and Click Image. Click Resize. Change Inches to Pixels. Change the largest number of pixels (either width or length) to 800, and the other number will change to it's comensurate number of pixels.
Then I Save As the same name, with (small) in parenthesis.
If you crop after you resize, it will increase the file KB.
HTH
Re: Picture Size.
Re: Picture Size.
Texian
>Set resolution to 300 dpi first. Crop second. Or vice versa if you have an older computer. Then set picture size so larger dimension is 640 pixels. Then adjust file size to about 100k. That should work on most forums.
Re: Picture Size.
An easier way *LINK*
Eddie Pacheco; San Jose, Ca.
>Go to the following link and download and install the "Image Resizer" for XP. (If you have an earlier version of Windows there's one for it too in a different page)
When "Image Resizer" is installed you will be able to post straight from camera memory chip, or picture folder, to e-mail. When you Right click on a picture file you will have a new option in the pop up window. Just below "Print" you'll see "Resize Pictures" as a new option. Click on that and you'll have 4 different of image sizes to choose from. Real easy to use.
MS Power Toys
Re: Picture Size.
Mike Stafford
Re: Picture Size.
Mike Stafford
>Dick, here is a link to Pixresizer. It doesn't get much easier than this. I have been using this to resize my pictures for at least 3 years. As far as WC is concerned you must have your pictures sized so that they are 80 kb or less.
http://bluefive.pair.com/pixresizer.htm
Re: Picture Size.
Re: Picture Size.
Carole Valentine
>Does the small version of Photoshop have a "Save for Web" feature like the full blown version? That's what I use. You specify the size in pixels then optimize to file size (80kb for WC)and that's it. It does a really good job without loss of detail.
Re: Picture Size.
Re: Picture Size.
>>...Does the small version of Photoshop have a
I have the full version, but Mr Google provided links to numerous discussions of the Save for Web feature in Photoshop Elements.
BTW, I use the Save for Web feature every time I save a copy of a picture for posting.
Re: Picture Size.
Re: Picture Size.
>Dick,
To get specific assistance, it would help to know what software you are using to reduce the picture's file size.
Don't get confused by changing the "resolution" - that's a count of the pixels in the image which will determine how big the picture is displayed on the viewer's monitor. It really has nothing to do with file size other than all else being equal, a little bitty picture will result in a little bitty file size. A "big" picture may have a large or small file size depending on the visual content and JPG compression level.
To reduce the file size without changing the size of the picture, you somehow need to change the "quality" or "compression level" of your JPG image when saving. Different software packages call it by different names. Some programs let you change this in the Save dialog box, others require you to go to an Options or Preferences dialog.
The basic steps are always the same:
1 - crop the picture to eliminate as much unneeded area around the subject as possible.
2 - change the "resolution" or the image size to make the picture nicely visible in the message, usually 500 0r 600 pixels in the long direction.
3 - choose what ever compression level is needed to make the file size acceptable to WoodCentral (80k)
Programs like Photoshop make this extremely easy - you choose the file size an it chooses the compression. Most other programs will make you guess at a compression level, save the file, look at the file size on the disk, and if it's too big, choose a different compression level and save the file again.
BTW, different programs use different numeric scales to specify quality levels. For example, PaintshopPro uses 1-99, where 1 makes a big file (with the highest quality) and 99 makes a very small file (that looks really bad). Photoshop uses numbers from 1 to 12, where 12 is the highest quality and makes the largest file. I saw one program the had poor features and only let you save as "Highest", "High", "Medium", etc. If your software does this, get some different software!
Re: Picture Size.
Re: Picture Size.
Jim Terry
>Photoshop Elements does have a Save For Web feature. I use it all the time to post photos to our website.
Re: Picture Size.
You're right, Eddie, except this...
Allen Neighbors
>is the same one I have, and it will not resize a photo if it's been cropped from the original size. You have to resize first, and then crop, and that won't always leave a good resolution.
Re: Picture Size.
i agree
robert davis
>you gave me this info a couple of years ago..works great
