Let's Be A Bit MORE Careful Here
>There's a very good reason that grinders' wheels are enclosed in metal. Grind wheels have a rather nasty tendency to fracture in use and then functionally explode in an eye-blink with no warning. If anyone here has experienced a piece of wood coming apart on the lathe, you ain't seen nothing and probably won't but your next of kin will if you use a grind stone this way.
Aside from getting fine abrasive material into your lathe bearings or scoring your morse taper (or both), these MT arbors are meant for buffing and stropping wheels. They're not intended to spin an abrasive wheel with the same precision that your grinder will, and it will be nearly impossible to balance the wheel for a good grind.
Take the few step over to your grinder, and leave your stones where they belong.
Rant Off
mm
