mirror drilling jig
mirror drilling jig
mirror drilling jig
>I spent part of the last 2 days working on this drilling jig. I've been drilling my mirrors the hard way for years. I decided it was time to make something that had a micro adjustable table, and an easy way to clamp the mirrors. This is what I came up with. It works great.
I also made a woodturning tool rest for my metal lathe. I'm working with a glass artist who wants to add metal parts to his glass. A few weeks ago I taught him to turn them using a wood lathe but it's really slow and you get too much chatter. These are long thin tapered pieces. I rigged up the metal lathe so we could rough them out using the metal tools and cross feed. then Put the wood tool rest on and fine tune the shape with spindle gouges and scrapers. This worked great. If you want to see how much longer a Thompson tool lasts turn metal. I turned one whole spindle with the Thompson gouge. I have to sharpen HSS tools at least 3 times or more to turn the same spindle.
Re: mirror drilling jig
mirrors
>I drilled and glued in the handles of all these mirrors today after finishing the drilling jig.
Michael Stadulis in Southern NJ
>Very nice idea and lovely work, John. Can you tell me how you setup the faceplate work? Do you screw into a glueblock. I'm planning on somethingfor my daughter and I'm a newb when it comes to faceplate work except for a bowl.
Mike
That's a pretty nifty and nice looking jig, John.
Eddie Pacheco; San Jose, Ca.
>Michael I turn the mirror heads by gluing a 3" square block to the face side of the mirror with CA and Accelorator. I put this in a chuck with 4" jaws mounted between the square corners. then I turn the 4" hole for the mirror. I break the CA joint by hitting it with a chisel and mallet. Then I mount the mirror on my 4 jaw chuck.
If you don't have 4" jaws mount the block on a wasteblock. I drill a hole in the center of the square block and then drill hole in the wasteblock. I glue the square block to the wasteblock by putting a dowel in the two holes without glue. This aligns them. Then turn the corners of the square block down until it fits the opening for the mirror. Use CA and accelorator to glue the mirror on. Turn the face side.
You actually use your workbench!
Mike Brazeau
>Nice work John. You continually amaze me with your ingenuity and productivity.
Allen Neighbors
>John Lucas, you're amazing. Truth.
Re: You actually use your workbench!
>I couldn't live without my workbenchs. I have 3 if you count the metal one. This one is my most used. I need to work on and improve my carving work bench. It's going to have cabinets and a downdraft dust collection system when I get done. The metal one came with the garage when I got the house and it's going with me. I've never had a heavy duty metal workbench before and now that I do I'll never give it up.
Bill Clark
>Great jig John, thanks for sharing. Your method of mounting the mirror blanks was also helpful. Your posts are always spot on!
EGAD!
Jorge Castaneda~Downeast Maine
