Re: Might be time to build a vacuum setup *LINK*
Carol - now in NC Nebraska
>Go to joewoodworker.com and read the whole vacuum section. Then revise your questions.
MDF is very porous. It must be sealed very well to work as a vacuum plate. The vacuum plate is what has the seal and that is where you "stick" the item, bowl or whatever. The area between the item you want to hold and the vacuum plate has a direct relationship to the ability to hold. The bigger the area (in terms of square inches) the better the hold. The area can be too big and then you can have an implosion. Kinda fun. Totally destructive. Somewhat dangerous.
Vacuum is not in and off itself a "pressure." It is a lack of positive pressure. If you removed the atmospheric pressure from an area, then the outside atmospheric pressure provides the pressure. Sound dumb, and its hard to get your head wrapped around it, but there it is.
Visualize air moving from the vacuum plate back through the pump into the outside world. Place items like air filters, one-way valves, etc. accordingly.
Another thing is that vacuum holds less well when sheer force is applied to the hold. Like when using a gouge against the wood. This is good for light cuts, not for hogging. I learned this with my CNC machine (when I had one).
joewoodworker.com has a lot of good information and is also a source of supply for the various items you will need. I used to teach vacuum clamping for woodworkers. IMHO, his site offers very good information, the right stuff and at a fair price.
Then if you want to try to pinch more pennies, come 'on back. We might have a few ideas. :)
joewoodworker site
