Sanding Speeds
Sanding Speeds
Sanding Speeds
MikefromTn.
>I have recently been working with some hard as concrete Maple. I normaly don't sand any faster than 1500rpm or so as this seems to get the job done. However at that speed, this Maple was taking too much time so I kicked it up to about 2300 or so. Much better if I watch the heat. Am I way off base with this? What's common with everybody else? Also, have I missed the abrasive guest on the Wed. chat. Ellis said something a few weeks ago about having a rep on.
Re: Sanding Speeds
Re: Sanding Speeds
richard jones
>Mike,
Actually, I've found that slower is better than faster when it comes to sanding. Now that I've got the VS to make it easier, I don't sand much faster than 750 or so, maybe a bit faster on a small spindle piece. Has made the paper last much longer and doesn't heat up the work as much, important on a thin bowl. I was getting a lot of bowls that were warping on the edge on the lathe, and I attribute that to the sanding speed/heat. Much better success rate now that I've slowed down.
I'm also curious as to what others feel about this.
Just my $.02..........
rich in va
Matthew 8:26
Re: Sanding Speeds
Ric Taylor
Re: Sanding Speeds
Ric Taylor
>Mike,
You didn't say how large that piece is, but unless it is a miniature, then you are sanding waaaay faster than most of us.
Ric
Re: Sanding Speeds
Re: Much too fast! Sanding speeds should.....
Jamie Donaldson
>...be slow enough that the sanding material touches the entire surface being sanded, and high speeds cause the sander to jump from one high spot to the next, and generate damaging heat in the process as well.
Re: Sanding Speeds
Re: Sanding Speeds
Brian Hahn in SW Wisconsin
>For pieces that size, I'd have the lathe going at 100-150 rpm and the disk sander at 600-800 rpm.
Make sure you are using good fresh sandpaper. Dull sandpaper and cheap sandpaper don't work worth beans on really hard woods.
Re: Sanding Speeds
I agree with Brian
Re: Sanding Speeds
Re: Sanding Speeds
Barry Turner
>Whatever works for you, but I wouldn't sand anywhere near that fast. A good rule is to sand (much) slower than you think you need to. I don't know the exact speed that I do most of my sanding at, but I suspect it's much less than 1000 rpm. If you are power sanding with a 2" disk, 400 to 500 rpm on the lathe and 800 to 1000 rpm or so on the drill ought to do the job just fine.
If you are hand sanding, with sandpaper held in the hand, it's still 1000 rpm or less. You might want to try a Scotchbrite pad between the sandpaper and your fingers. It keeps the fingers cool and provides a pad for the sandpaper that allows it to conform to the shape of the surface better.
Be sure to use fresh, sharp sandpaper and change it often. Don't skip grits. Be careful not to round over crisp edges.
Re: Sanding Speeds
Thanks guys
MikefromTn.
>Thanks guys. I'll slow it back down to normal. I was careful with the heat. It just seemed to go a lot quicker at the higher speed.
Thats a 10inch bowl that the "jug" is sitting in. Hardest batch of Maple I've ever turned. Nice looking wood though it has been a little grainy with a few cracks. I've filled them in with black epoxy for a nice effect. Good turning.
Re: Sanding Speeds
Re: Sanding Speeds
robo hippy
>I used to sand at higher speeds, but was told that slower speeds work better, not only because of the heat issue, but also because of bouncing. All of my bowls are warped, and I can't have the lathe running at higher speeds, and keep the sandpaper or discs on the wood. I have the lathe set at around 10 to 60 rpm, and the drill set at about 600 or less, especially with the finer grits. Now my whole logic was that by sanding at a higher speed, you would get the job done faster. Well, after slowing down a lot, I get the job done as fast, if not faster. The abrasives cut better at slower speeds.
robo hippy
