Finishing with Linseed oil
RPE
>I know this has been discussed before, but I can't find the discussions! What types of finish can I put over BLO. I will let it dry for a few weeks before I attempt. I just wanted to "pop the grain" on a beautiful piece of Walnut I have.
I'd like to put gloss Deft over it. If Deft won't work, what about Minwax Fast dry Poly. I want a High gloss finish to show off the wavy grain in the Walnlut.
Thanks
RP
Re: Finishing with Linseed oil
Peter Teubel
>Give Woodcraft Urethane Oil a try (made by McFaddens). It contains BLO and poly. Pops the grain and with multiple coats builds up a nice finish that can be buffed to a high gloss shine.
georgetroy
>I don't use boiled linseed oil and/or Watco, takes too long to dry in my opinion. I do use a seal coat of lacquer, then urethane oil. This is the way it's been for over 20 years.
Ben
>Shellac is the universal binder, it will adhere to any finish. Put a coat of blond shellac over your BLO finish then put your final top coat of choice over the shellac.
Ben
Russ Fairfield
>Compatibility of finishes is simple. If their thinners are soluble, then the finishes are compatible. If they are totally cured and dry, and all of the thinners have evaporated, everything sticks to everything else. We do need to abrade the surfaces so the next coat can get a grip on whatever is under it.
Truly "dry" on an oil like Linseed oil can take awhile - at keast a week in the best of conditions, and a couple months when the outside temperatures are below 65F. If you can smell it, it isn't "dry".
All oil finishes can be mixed because they all use the same thinners. Water and oil don't mix, and that means waterborne finishes won't stick to uncured oil finishes. Lacquer generally won't stick to an uncured oil, but it can sometimes be forced if it is applied with a rag and worked into the oil.
Shellac is a universal finish, and is used as a barrier coat between incompatible finishes because shellac sticks to everything and everything sticks to shellac.
Thanks for your responses
RPE
